Gear and Equipment
Tube Heads
Gear and Equipment
04-20-2007, 12:49 AM
Anthony
Posts: 9 - iTrader: (
Tube Heads
I have recently made the decision to make the jump from solid state to
tube amps
and could use some advice. My two main guitars are an
Ibanez Jem
with DiMarzios and A Steven Carpenter 7 string with active EMGs. I have done alot of listening and just can't find any one amp that I like the clean channel and the distortion channel as well as tolerating my 6 string and my 7 string tuned to A. I have decided though that it needs to be at least 2 channels and be user friendly when it comes to changing the tubes out. The only one I am seriously considering now is the Randall RM100. Any other ideas?
Anthony
Find all posts by Anthony
04-20-2007, 02:04 AM
KyleChx
Posts: 41 - iTrader: (
Re: Tube Heads
check out the B-52 AT100... its a tri rectifier so u have 3 diff amps (in a way) to choose from... lots of power 3 channel and effects loop and a nice reverb... really really versatile and reasonably priced... i was sceptical at first but i love mine now... i use it with an rg550 and a LP... the amp has a lot of play on it and wont let you down
KyleChx
Find all posts by KyleChx
04-20-2007, 04:23 AM
David McCarroll
Posts: 2,049 - iTrader: (
Re: Tube Heads
Who you callin'
Tube Head
there buddy?
The B52 got great reviews in Guitar Player BTW.
If you are on a fairly limitless budget you can't go past the Boogie Rectifiers for what you are looking for. Not cheap, but very good indeed!
Cheeers
David
David McCarroll
Find all posts by David McCarroll
04-20-2007, 10:11 AM
Anthony
Re: Tube Heads
Honestly I would have never thought B 52. I will have to check them out. 3 channels is even better. As far as some of the really expensive amps go, are they really worth the extra skins? I would like to stay under 2K but I don't have to. I will just have to wait longer.
Anthony
04-20-2007, 11:01 AM
thadood
Posts: 90 - iTrader: (
Re: Tube Heads
Too much 'Boogie love here, IMO.
Check into
Genz Benz
' El Diablo. I use it with the accompanying Gflex 2x12 cab and it outperforms his 6505+ with the matching 4x12 slant in both volume and
bass response
edit: Not to mention I play in A, as well.
thadood
Visit thadood's homepage!
Find all posts by thadood
04-20-2007, 11:52 AM
Anthony
Re: Tube Heads
My problem now is when I go below C on the seven string I loose the response of the guitar and the tone drys up. I have heard good things about the genz benz but no one around here sells them. Thanks though, I will add them to my list.
Anthony
04-20-2007, 03:22 PM
racerevlon
Posts: 932 - iTrader: (
Reviews: 107
Re: Tube Heads
Hughes &
Kettner Triamp
MK II. 6 different channels ranging from pure Class A on channel 1A to
death metal
on channel 3B. If price is a consideration, bump down to the Trilogy.
racerevlon
Find all posts by racerevlon
04-20-2007, 09:05 PM
Andy43
Posts: 814 - iTrader: (
Re: Tube Heads
Well, it depends on what kind of tone you are going for, but you have several options. You will need an amp that can tolerate all the bass that the 7-strings give out. Some amps that are awesome with low tunings are:
-VHT
-Mesa/Boogie
-Diezel
All the amps above are relatively different sounding, but all go well with 7-strings. There are probably more, but those are all the ones I've tried. Do some listening to artists that use some of the above amps and see which one you like best. I don't recommend Marshall-y sounding amps for de-tuning.
Andy43
Find all posts by Andy43
04-20-2007, 10:35 PM
Darin
Posts: 2,459 - iTrader: (
Re: Tube Heads
Wow, you got ALOT of choices. Everyone here is going to point you in a different direction too. Best advice, demo the head you're considering with YOUR guitar, AND your cab. Take them to the
music store
, and plug all your stuff in. The only way you would not do that is if they let you take it home. But spend some time with it. They ain't cheap.
Oh, and demo the JSX.
Darin
Visit Darin's homepage!
Find all posts by Darin
04-21-2007, 12:07 AM
Anthony
Re: Tube Heads
Well thanks everyone for the advice so far. So many choices and yet still so hard to sound original. But I guess thats the trick isnt it. Well I would have never considered some of the recommendations here so I guess I will keep trying them out.
Anthony
04-21-2007, 03:03 AM
Gurj
Posts: 1,912 - iTrader: (
Re: Tube Heads
I'm with Darin
Try a JSX or even a XXX.
Alternatively, maybe an Engl. There's lots of sound clips of their amps (and a few Framus) here
http://rocksolidamps.com/index.php?c...aylist&mid=155
Gurj
Find all posts by Gurj
04-21-2007, 12:45 PM
MadRyan
Posts: 246 - iTrader: (
Re: Tube Heads
The JSX is pretty tough to beat. Much "rounder" sounding than the XXX IMO. The JSX seems to be voiced to cut through the mess better.
MadRyan
Find all posts by MadRyan
04-21-2007, 01:30 PM
supermau
Posts: 1,064 - iTrader: (
Re: Tube Heads
Check out the Orange Thunderverb. It'll cost ya though.
supermau
Visit supermau's homepage!
Find all posts by supermau
04-21-2007, 04:50 PM
shogun
Posts: 1,525 - iTrader: (
Re: Tube Heads
if your looking for a balls to the wall tone for heavy **** and DM get a Genz Benz el diablo 100c ( 212 combo) or head n 212 cab..
shogun
Visit shogun's homepage!
Find all posts by shogun
04-21-2007, 05:01 PM
guitarman13
Posts: 388 - iTrader: (
Re: Tube Heads
Don't forget to try a Carvin Legacy. I tried a JSX, some marshalls, a mesa, and then I tried the Legacy. And to me it sounded much better than all of them. I thought it would be "dark" sounding like most people have said, but it's not if you have the settings right. I absolutely love my Legacy.
guitarman13
Find all posts by guitarman13
bass response
clean tone
death metal
genz benz
ibanez jem
kettner triamp
music store
tube amp
tube amps
tube head
how to set up a tube screamer
how to tell when preamp tube goes bad
how can i build my own tube amp
how do I run several amp heads through on cab
how to turn a tube amp on
3 EL34 Tube Heads... Carvin/Hughes & Kettner/Mesa
Robotechnology
01:58 PM
Tube tube tube. Help me out please.. Marshall JCM2000DSL
SHsu516815
Gear and Equipment
29
06-26-2003
05:40 PM
Calling All Tube amp experts! (tube emergency?)
Greg RG7
Tech: Setup, Repairs and Mods
07:45 AM
Legacy the unrelenting tube eater! - Getting ready for solid
Darin W
Gear and Equipment
09:36 AM
Real Tube - I found a great pedal
jeff l
Gear and Equipment
12:21 PM
06:07 PM
