Gear and Equipment
TUBE Vs. Solid State Amps!?
Gear and Equipment
10-23-2002, 04:22 AM
DrPuls
Posts: 123 - iTrader: (
Hey guys... Okay heres my dilema, Im hearing mixed things about both amps...one does this...one does that. bla bla bla... I WANT TO KNOW what is the difference in sound... All i really want is to be able to turn the amp up and have it sound the same as if it were at low volumes. For example the amp i use now *cough* (a fender) when its low volume it sounds great...but when i crank it up it sounds like CRAP...starts buzzing ratteling, and it just doesnt sound the same.
Now.... What do i need to solve this problem.
Thanks Guys...
DrPuls
Find all posts by DrPuls
10-23-2002, 07:49 AM
Polaris20
Posts: 1,418 - iTrader: (
A. Just go play the amps. Nothing we tell you is going to give you a definitive answer .
B. Why do you need to start multiple threads about the same subject?
Polaris20
Find all posts by Polaris20
10-23-2002, 09:25 AM
jeff l
Posts: 554 - iTrader: (
DrPuls,
most any SS amp I've ever played would fart out at high volumes. They just start clipping in a really nasty way. Conversely, the beauty of (and fault of, if you have cranky neighbors
) a tube design is that it generally gets *better* as you crank the power tubes.
I don't know of much you can do to make a SS amp sound any better at higher volumes than it's design will allow....replace it and maybe use the Fender for a low volume
practice amp
jeff l
Find all posts by jeff l
10-23-2002, 09:55 AM
wallopwallop
Posts: 330 - iTrader: (
jeff l
DrPuls,
This is why the Randall Warhead has silly amounts of headroom (300w?). To get a killer sound at silly volumes, tranny amps need lots of power.
wallopwallop
Find all posts by wallopwallop
10-23-2002, 11:30 AM
JESTER700
Posts: 2,234 - iTrader: (
RATTLING is not the amplifier itself; it's cabinet, speakers, etc. - something mechanical. "buzzing" could also be, depending on the meaning of "buzzing". Thus, it may not be a tube vs. SS issue at all.
I can't imagine why anyone would need more than 50 watts in a
solid state amp
. My Carvin SX50 is so friggin' loud on *3* in an enclosed space that I'd need earplugs, and there goes the sound right there. If you need more than that, you need a PA.
Now, if you want that "tubes a'cookin' " sound, and you don't think solid state or digital emulation is close enough - more power to ya - go for it. But take care of your ears...
JESTER700
Find all posts by JESTER700
10-23-2002, 12:42 PM
Globbits
Posts: 677 - iTrader: (
Tube wins everytime. Crisp distortion and crunch, smooth overdrive, clean as a whistle at low gain high volume, great blues sounds....
Globbits
Find all posts by Globbits
10-23-2002, 01:40 PM
urkoman
Posts: 379 - iTrader: (
Valves all the way.
urkoman
Find all posts by urkoman
10-23-2002, 02:42 PM
mike777
Posts: 656 - iTrader: (
MOST players will prefer tube (aka: valve) amps but tone is 90% the player anyway. I prefer
tube amps
also but I will never say that I despise solid state stuff either for the following reasons: So, it really just comes down to what meets your needs. There are great hybrids out there and also, there are some sounds that one kind of amp can do that the other can't.
Shop around. YOU are the one who'll be reliying on it so YOUR opinion is ultimately the only one that matters. So, if all of us recommended the exact same amp and you have repeatedly tried it and didn't like it-don't get it. We trust you and will respect your right to individuality. Good luck!
Mike 777 Haug
mike777
Find all posts by mike777
10-24-2002, 07:26 PM
Gresh
Posts: 1,416 - iTrader: (
Hard to beat good tube circuitry. but you really can't appreciate it unless you're right there in front of it. Go play a nice
tube amp
and you'll understand.
Gresh
Find all posts by Gresh
10-25-2002, 04:51 PM
dannybigtime
Posts: 137 - iTrader: (
Tubes are for kids and people that can't play through a real amp. I'll name you 30 great guitarists that play tube for every clown that uses tubes
dannybigtime
Find all posts by dannybigtime
10-25-2002, 05:24 PM
jeff l
dannybigtime
WTF?!
jeff l
10-25-2002, 05:34 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
I personally hate the tube purist. They dismiss ALL
solid state amps
. The thing about tubes is once they warm up they begin compressing the signal naturally. thats the tonal difference most people hear. I just use my korg to slap a little compression on a solid state amp and I get the same frequency response. I actually personally prefer tubes but there is nothing wrong with using a good solid state amp. Randall and Marshall make some KILLER solid state amps that are to die for. Its just that typically solid state have been low end amps since it is cheaper to make a circuit board than a row of tubes
sniperfrommars1
Find all posts by sniperfrommars1
10-25-2002, 06:13 PM
Carlo
Posts: 835 - iTrader: (
I recently saw a
Rob Balducci
guitar clinic and he was using an Ibanez solid state amp, with a bunch of tonelok pedals in front. And man, he sounded goooooooood
I have an Ibanez TB 25 and I'm surprised with some of the nice tones I get from it, especially when I put my DOD YJM oedal in front. IT ROCKS!
Carlo
Find all posts by Carlo
10-25-2002, 09:29 PM
DrPuls
sniperfrommars1
Now i now why tubes are hella spensive compaired to soid state amps.
Thanks!
DrPuls
10-26-2002, 08:13 AM
Skarekrough
Posts: 266 - iTrader: (
JESTER700
I can't imagine why anyone would need more than 50 watts in a solid state amp. My Carvin SX50 is so friggin' loud on *3* in an enclosed space that I'd need earplugs, and there goes the sound right there. If you need more than that, you need a PA.
Sometimes you aren't always afforded an enclosed space or a PA.
Once you start playing outdoor gigs you'll want that headroom. Once you get on large stages where your amp is a solid 25 feet behind you you'll appreciate the overhead. Once you end up in some comlplete and total barn with soggy walls and no PA micing for the amp you'll appreciate it.
Skarekrough
Visit Skarekrough's homepage!
Find all posts by Skarekrough
combo amp
fender bassman
power amp
power amps
practice amp
rob balducci
solid state amp
solid state amps
tube amp
tube amps
tube saturation
how to set up a tube screamer
how to turn on tube amps
what pros use as their first Amps
when to change pre amp tube
what amps have brown sound
01:03 PM
