Old 05-18-2008, 01:15 AM
kpinks  is offline
Posts: 63  -  iTrader: (0)
Tuners in signal chain
Just wondering if anyone knew where exactly in the signal chain, should the tuner be? Currently, I have the guitar going into the tuner first and then on to the rest. But I was considering moving the tuner down later in the chain?
Thx
Kev
Old 05-18-2008, 01:25 AM
rty13ibz98  is offline
Re: Tuners in signal chain
it usually goes first, so as to get the unaltered guitar signal. also, some tuners, like the tu-2, can be used to kill the signal from the guitar. not a rule, just a typical.
rich
Old 05-18-2008, 11:17 AM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
I run it at the end, so when I mute, any gain pedals will be muted as well, and not bleeding noise into the PA.
Also, since I run a compressor, it helps keep the signal strong into the tuner.
Old 05-18-2008, 12:12 PM
bammbamm  is offline
I have a rack system and run my tuner from the recording output of my preamp.
That keeps it out of the chain and does what I need it to do... NOT COLOR MY SOUND.
If you're running pedals, you could run out from an unused stereo output of another pedal, if you don't want it inline with your signal.
Old 05-18-2008, 12:18 PM
kotornut  is offline
Posts: 1,847  -  iTrader: (0)
I usually run it first. I don't know why. Maybe I used to think that effects would hinder my ability to tune so I did that. I don't think distortion or delay would hinder itmuch and that's all I use now but oh well it works well there.
Old 05-18-2008, 01:39 PM
Darin  is offline
if your tuner is coloring your sound, you need a new tuner
Old 05-18-2008, 09:21 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
Tuners destroy your tone. I pulled my Planet Waves for a Boss, that sucked so I pulled it and went for a Peterson. THAT sucked my tone so now I fly solo.
I keep a spare tuner with a short cord on hand when needed.
Old 05-18-2008, 11:23 PM
kotornut  is offline
If you're reffering to me:
I don't think it is. I can't hear any difference. I think people are a little overboard on the "kill your tone," thing.
Old 05-19-2008, 12:01 AM
Mr.WizardNeck  is offline
Posts: 917  -  iTrader: (0)
How the hell does a tuner mess with your tune when it's true bypass?
Old 05-19-2008, 12:27 AM
kotornut  is offline
That's what I want to know. I seriously think most of the "it kills your tone," stuff is just bandwaggoning.
Old 05-19-2008, 02:54 PM
Toadfish  is offline
Posts: 227  -  iTrader: (3)
I have a Peterson on my board - last in the chain - and it works great. Not tone suckage to my ears. I use the gain from my amp, so I'm sending it a pretty clean signal anyway.
Old 05-20-2008, 12:17 AM
That's what my roomie uses and it's pretty damn nice.
Old 05-20-2008, 12:44 AM
bammbamm  is offline
No, it isn't, I can clearly discern a difference if it's in line with my signal chain.
Why run your signal though a device if you don't have to?
And who says your tuner is "True Bypass"?
I have had Korgs, Boss, Arion, Sabine, etc, I don't keep them in the signal chain.
No need. I have a line out that works fine and it's one less thing I have to troubleshoot should there be an issue.
I'm not a bandwagon kinda person, don't be an anti-bandwagon person, especially if the wagon is headed toward a place with better tone...
Old 05-20-2008, 02:45 PM
Repner  is offline
Posts: 99  -  iTrader: (0)
I heard that the Korg DTR-1 and DTR-2 can be quite noisy. The DTR-1000 and DTR-2000 seemed to solve that problem.
That's just what I've heard though. I haven't tried them myself
Old 05-20-2008, 03:11 PM
microdmitry  is offline
Posts: 1,687  -  iTrader: (4)
I don't know how, but my Peterson Strobo Stomp totally sucks all life out of the guitar when it's in the chain. Yes, I know it's true bypass, yet it lowers the signal level somehow. I've discovered this when I built my pedalboard. The intention was to keep it first in the chain and just engage it as needed. Once I assembled everything together, it sounded like ass. No gain, no life, nothing. Naturally, the tuner being true bypass, I blamed my BOSS pedals and Ibanez wah immediately, so I started removing them one by one. In the end I was left with just the tuner in the chain and it killed everything.
I need to open it up and see what the heck is going on. It's probably their "direct" XLR output circuitry that's messing with the signal.
boss pedal, boss pedals, distortion pedal, korg dtr, planet waves, rack system
Pedal placement in signal chain carlos seo Gear and Equipment 13 04-08-2009 03:09 PM
BBE 462 in signal chain Draco Gear and Equipment 1 09-09-2006 09:37 PM
signal chain question Elliseye Gear and Equipment 2 08-27-2006 03:54 AM
Running a reverb/delay in the signal chain Jeff Gear and Equipment 9 08-23-2003 03:42 PM
Rack signal chain question - splitting signal to tuner luther Gear and Equipment 4 12-14-2000 12:06 PM
