Old 02-17-2003, 08:41 AM
Polaris20  is offline
Posts: 1,418  -  iTrader: (0)
Ultimate hard rock 40-60 watt 1x12 tube combo?????
I am looking for an all tube 1x12 combo, between 40-60 watts. The way I see it, there are the following choices:
Peavey XXX 1x12 60w
Marshall DSL401
Mesa F50
Any more suggestions to check out? I really am not a huge Fender fan, and I would like to keep it sub $1000, which these all fall under.
Old 02-17-2003, 09:02 AM
Soup Kitchen Studios  is offline
Posts: 401  -  iTrader: (0)
Carvin Nomad springs to mind... there must be a lot of amps in this range though?
Old 02-17-2003, 09:10 AM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
Moreso than the Mesa F series, I'd recommend the Nomad series. I have a Nomad 45 1x12, and it absolutely rocks! 3 channels (2 modes per channel), solo boost, parallel FX loops, spring reverb, and all tube, of course.
--B
Old 02-17-2003, 09:33 AM
track7  is offline
Posts: 351  -  iTrader: (0)
i will HEARTILY second the Mesa Nomad..tons better tone than the F50 and the extra channel and more modes than you can shake a stick at as bduersch rightly said. The 45 also has the extreme mode! which is very beefy
track
Old 02-17-2003, 09:36 AM
track7  is offline
oh yea me and bduersuch were refering to the Mesa Boogie Nomad amps..not the carvin that dave linked too.
that may well be a great amp too. Keep your options open and try 'em all
track
Old 02-17-2003, 10:03 AM
Damn that was fast. The Carvin Nomad looks cool, but I was thinking something that will release the fooking fuurrrrryyyy!!!
I'll check out the Mesa Nomad, I hadn't thought about that. Anyone know how much it retails for?
Old 02-17-2003, 10:17 AM
bduersch  is offline
Can't remember what the retail is, but I paid ~$575 used for my Nomad 45. Worth every penny! Mine's got plenty of fury, and I'm not even using "extreme" mode!
--B
Old 02-17-2003, 11:20 AM
track7  is offline
--B
GEEZ!! 575 i hate my country
i paid the equivelent of just under 2000 for my 1x12 45watt nomad.
i would have got it used but they are soo scarce..
huh at least its cheaper than the rectos marks etc..
Old 02-17-2003, 11:22 AM
rilla  is offline
Posts: 111  -  iTrader: (0)
I'd look at a Rivera combo... they're a bit less "metal" than the Mesas, but it sounds like thats what youre after. Something like an R-series, or Fandango/chubster if you want a punchier more "modern" tone
Old 02-17-2003, 12:13 PM
nocebo  is offline
Posts: 56  -  iTrader: (0)
check out the Yamaha T50. soldano designed. not made anymore, though.
colin
Old 02-18-2003, 12:06 PM
I got's to go to GC and try out the Nomad, and then see if I can find a good deal on a used one. Something tells me if the F50 is 1K new, the Nomad is probably quite a bit more.
Old 02-18-2003, 12:54 PM
Drew  is offline
Posts: 4,706  -  iTrader: (4)
the 45 watt one is probably just under that, actually. A 55 will probably set you back 1100-1200, though.
-Drew
Old 02-18-2003, 01:58 PM
track7  is offline
from what i remember...well in the UK anyway Nomads are the same price as the F series...which I could never understand cause compared to the nomads the F series sounded like mouldy ass....well a very nice mouldy ass but still a mouldy ass in comparission
Old 02-21-2003, 10:26 AM
Someone also mentioned to me to check out the Rivera Fandango 55 1x12. It's supposedly a fine sounding amp.
Old 02-28-2003, 08:51 AM
BenoA  is offline
Posts: 256  -  iTrader: (0)
Traynor YCV40 + a good OD pedal...
Very nice lil' 40 watt all-tube 1x12 combo...
Goes from very clean to mid crunch and push the overdrive channel with a good pedal and you'll be into hard rock territory...
I used to play mine on top a Marshall 4x12 and it was rockin'!!!
BenoA
boogie nomad, boss metal zone, marshall dsl, mesa boogie, mesa boogie nomad, mesa nomad, spring reverb
