Using another amp's preamp with your existing amp. - Jemsite
post #1 of 5 (permalink) Old 08-15-2010, 08:25 AM Thread Starter
Hi,
I use a fender protube 60w (all tube) and I have a Marshall valvestate on the corner on the room (I never use it lol ). This valvestate amp have a tube preamp with a gorgeous tube distortion (the amp section is solid state, so it sucks). I just want to use the preamp section of this amp in my fender and to get that gorgeous tube preamp, with my fender tube amp section.
The valvestate has a 3 send options...
A "send" (with loop level between -20 and 0 db) and 2 for effects return (left & right) with a knob to control it.
The fender amp have a effect loop (send and return) with a switch with -24, -11 and +2 db and a know in the front to control the mix.
Can I try this? I think this could be better than any modern modeler and I could get that awesome tube distortion of this amp, with a tube amp section of a fender that can give me a great flexibility to play.
Anyway... Can I try this carefree??? Any sugestion to do it?
Vintage_freak_forever is offline
post #2 of 5 (permalink) Old 08-15-2010, 09:29 AM Thread Starter
Re: Using another amp's preamp with your existing amp.
This is the amplifier that I want to use as a preamp
This is the one I'm gonna use as a "amp" section.
post #3 of 5 (permalink) Old 08-15-2010, 02:58 PM
Reviews: 130
Doesn't the Marshall have a Line Out? If not, try running the send of the Marshall into the Return of the fender.
Cheers,
Race
racerevlon is offline
post #4 of 5 (permalink) Old 08-17-2010, 09:25 AM
Hook up Send from Valvestate into Return on Fender. Keep return on Fender at -11dB to start with. Start with volumes very low on both amps. You don't want to destroy anything.
You need to turn the Fender channel volume to zero. It can't be used when accessing the return only on the Fender because the Fender's preamp section is cut off. If it's not cut off, turn it down to zero anyway.
If you want to have both Fender and Marshall, use a 2ch effects looper pedal. Hook up like this:
1. Guitar>Input of looper
2. Fender send>ch1 return of pedal
3. ch1 send from pedal>Fender input (front of amp)
4. Marshall send>ch2 return of pedal
5. ch2 send from pedal>Marshall input (front of amp)
6. Output of looper>Fender return
A picture may explain a thousand words. Here's part of my setup below:
You may or may not get a pop when switching. I don't have an issue with my setup above.
In fact the looper pedal above is a parallel loop pedal that allows me to blend and adjust individually the volume outputs of both the Mesa Recto and any other preamp connected to ch1. Works like a bloody charm. I can also send to the output of the looper an unaffected clean guitar signal through either ch1 and/or ch2. How cool is that?
I have 4 rack mount preamps and two valve drive pedals that I still need to hook up to test. At the moment, I don't see an issue.
One thing you need to know if you think the parallel idea is good; one of the loop channels NEEDS to have a phase switch. This is required because you don't know if a preamp's output, hooked up in this method, will be in or out of phase with your amps preamp. If it's out of phase, it'll sound weak and gutless. Both need to be in phase.
Hope it's enough info for you. Keep on rockin'....
EDIT: By the way, I can switch the above loop pedal to have both on or one loop at a time or bypass completely to have only the guitar signal going to the power amp > ***super clean***.
Blaklynx is offline
post #5 of 5 (permalink) Old 08-26-2010, 11:19 AM
it should work just fine, from send on marshall to return on fender. The only thing to worry about is if your first amp has tube power amp, it needs to be loaded all the time (either speaker or dummy load) or very very bad things will happen.
bancika is offline
amps , mix , preamp , tubes
Human Verification
Similar Searches
spray painting over existing finish? g1ahn Other Ibanez Guitars (including Premiums) 7 05-01-2010 03:31 AM
Plug tube head into existing 2x12 combo speakers? chaos731 Gear and Equipment 5 08-27-2008 09:59 AM
Painting amp's fabric front JN777 Gear and Equipment 5 05-13-2007 02:42 PM
need new phone on existing plan vette6600 Off-topic / Miscellaneous 5 09-01-2006 01:47 AM
New pickup - Does my description match an existing PU? juiceofvenus Tech: Setup, Repairs and Mods 1 07-19-2001 02:52 PM
