Old 12-21-2008, 06:07 AM
guitarnoize  is offline
Posts: 373  -  iTrader: (0)
Using the tube overdrive or clean channel with a pedal?
What do you recommend? I was watching an Andy Timmons video where he said his main tone is achieved using a Tube Driver with the clean channel of his Stiletto. I wondered what is the most common usage? I cranked my Genz Benz Black Pearl at rehearsals the other day and didn't need my BB+ but then wondered if I would be able to use the amp's boost function to actually boost the volume rather than the gain which could be handled by the BB+? Or would it just boost the gain not the volume?
I can't test this at home as I have to really crank it to get the true tone.
Old 12-21-2008, 07:35 AM
Tank  is offline
Posts: 926  -  iTrader: (0)
Reviews: 65
Re: Using the tube overdrive or clean channel with a pedal?
There is no "law" how to use it.
Everything that sounds good to you and helps you implement YOUR tone is ok.
I sometimes use a TS on the clean channel of my amp, sometimes I use the DS-1 or TS on my already distorted channel, to boost or compress the sound.
Noone can tell you what YOU will sound like doing it. So the thing is: You will have to try yourself what sounds good for you...
Old 12-21-2008, 10:52 PM
Fair enough. I'll have to play around next rehearsal.
overdrive, tube amp
overdrive pedal! callen3615 Gear and Equipment 9 08-06-2008 03:26 AM
Overdrive: Tube and Solid State kadeks Gear and Equipment 10 10-26-2007 04:55 PM
Clean or Overdrive channel eg Gear and Equipment 9 02-13-2003 10:25 PM
HELP, i need help on fixing my amp!! - My clean channel is w wolfgang Gear and Equipment 0 07-19-2001 01:27 PM
Probs with clean channel on Tremoverb - only comes out low v trapzilla Gear and Equipment 2 01-22-2001 05:38 AM
