Valve Amp question
I am currently looking to buy a valve amp and I have been looking at the Laney range, the one in particular I am looking at is the VC50.
Looking at the specs of the amp, it says it uses two el34s as output valves, but when I look at most other amps stats they usually have output valves and preamp valves. Are they just not listing the valves, or does it not use them. Another thing I noticed about htis amp is it's described as using RMS or something along those lines.
Anyone give me a clue? As I clearly don't have one.
Edit : Ok checked out the manual for the amp, and well duh it has preamp valves, they just didnt list them on the main site specs.
Still could do with knowing what RMS means.
I'll leave this post here for people to laugh at :P
