Gear and Equipment
Volume Pedal that will NOT affect tone AT ALL!
Gear and Equipment
04-08-2003, 01:36 AM
mechanyx
Posts: 166 - iTrader: (
Hey ppl, I'm looking for a
volume pedal
that won't color my tone AT ALL. I don't mind it introducing a little noise as long as my tone is still there. If you know my rig, then you know I'm completely hardnosed in my stance. Money is not a concern.
As a metric for what I'm after, when the volume pedal is set to be all the way up, it should sound as tho you aren't even using a volume pedal.
Thanks, Rich
mechanyx
Visit mechanyx's homepage!
Find all posts by mechanyx
04-08-2003, 03:55 AM
nuno
Posts: 4,725 - iTrader: (
what
volume pedals
have you tried till now? which one gave you this problem?
nuno
Visit nuno's homepage!
Find all posts by nuno
04-08-2003, 10:50 AM
Gearjunky
Posts: 169 - iTrader: (
Get an
Ernie Ball
It's direct wired. If you feel the need, you can always upgrade the internal wiring to heavier guage wire.
Don't forget your George L's cables if you want true sound.
Gearjunky
Find all posts by Gearjunky
04-08-2003, 12:35 PM
oooo
Posts: 338 - iTrader: (
I second the Ernie Ball. Stay away from any that require power (Morley). I have both and the EB is transparent.
oooo
Find all posts by oooo
04-08-2003, 03:32 PM
Drew
Posts: 4,538 - iTrader: (
It was my understanding that an EB pedal gave a slight boost when it was nose down... or is that adjustable?
-Drew
Drew
Visit Drew's homepage!
Find all posts by Drew
04-09-2003, 12:20 AM
oooo
Mine doesn't. You can adjust the taper, and I'm sure it wouldn't be a problem adjusting where the pedal throw ends on the pot. Seems like a really simple mechanical design.
Anybody else notice if theirs has a boost effect?
oooo
04-10-2003, 02:40 AM
steve
Posts: 590 - iTrader: (
No boost; it's passive. The max it can give is 'no loss'...
I have two; I use them as
expression pedals
for wah and volume - they're built like tanks.
(Tested 'em out as regular volume pedals first, to make sure they were working as intended, then hooked 'em up to the Bradshaw controller. Nice as expression pedals.)
steve
Visit steve's homepage!
Find all posts by steve
04-10-2003, 03:09 AM
mechanyx
Cool, I guess I'll try and snag an EB.
Anyone have any experience with any less mainstream pedals?
Thanks, Rich
mechanyx
04-11-2003, 12:48 AM
Jimi D
Posts: 737 - iTrader: (
Steel players and a lot of country cats use Goodrich pedals... They're very high quality, low profile volume pedals, built like tanks, utterly transparent, and maybe the only production volume pedal I've ever seen that is better than an Ernie Ball... Personally, I have an Ernie Ball on my board, and am perfectly happy with it, but the Goodrich pedals seem to have a smoother taper that allows for a little more movement (read: more control) for smoother volume reductions... They're pricey though, and you'll almost certainly have to order one.
Jimi D
Visit Jimi D's homepage!
Find all posts by Jimi D
04-11-2003, 02:17 PM
mechanyx
Wow, these Goodrich pedals look amazing. Does anyone have any experience using the 1 in and 2 out setup?
Thanks, Rich
mechanyx
04-11-2003, 02:37 PM
Gearjunky
I have a Goodrich L-120. It is really cool because it's really low profile and has a great sweep. The only reason I didn't use it in my main footboard is that I needed the jacks to come out the front of the pedal to keep my footboard dimentions.
I use it all the time when playing through a head or combo.
I bought mine mint condition down in Georgia at a pawn shop for $20, but from what I've seen they are close to $250 new.
If I put it side bu side with the EB, there is no sonic difference, just a different feel.
Gearjunky
04-11-2003, 02:41 PM
mechanyx
Yeah, some places charge that much. I've found the 120 new for about $130 and the 10K new for $175. I think I'll buy several and just sell the ones I decide not to use.
mechanyx
04-11-2003, 02:47 PM
darren wilson
Posts: 4,190 - iTrader: (
Does Goodrich have a Web site with more info? I can't seem to find anything.
darren wilson
04-11-2003, 04:10 PM
mechanyx
If they do, I wasn't able to find it either. I actually had to email an actual 10K owner to find out if it had the same 1 in 2 out setup that the 120 has as all the vendors seem to just post stuff that sounds like it came out of a brochure. He told me that it did have the same setup. I'd never heard of the company before yesterday. I'm imagining there is very little info readily available.
mechanyx
ernie ball
expression pedal
expression pedals
volume pedal
volume pedals
who has amazing tone
what is the pedal board rigs
how much do pickups affect tone
what distortion pedal can take guitars string 10-60
What amp sounds good with the Jemini pedal?
03:56 PM
