Old 03-03-2004, 02:33 PM
trouble311  is offline
Posts: 643  -  iTrader: (3)
Volume Pedals
Well, here's the deal.
I want to get 3 separate volume pedals, ONE to put in front of my amp to control the signal to the preamp (control the drive, because I really don't like messing with my volume knob, much harder to get it back where I want it...I am anal.), ONE to put in the Effects Loop to do volume swell type stuff (once again, I hate using my knob for that), and ONE to use as an expression pedal for my G-Major.
I am thinking either Morley Little Alligator or Ernie Ball Mono or Stereo Volume...what do you guys suggest? Or a combination of the two?
I was thinking maybe the Little Alligator in front, because with it's rhythm/lead volume settings, I can set my heel back to be my "clean distortion" tone, then the toe down to be maximum drive, then two Ernie Balls for the volume swell and the expression (since I want them to go to TOTALLY off in the heel down position).
Opinions/concerns?
Old 03-03-2004, 04:23 PM
carlos seo  is offline
Posts: 503  -  iTrader: (0)
Reviews: 5
I had something similar to that. In front of the amp I used a Morley PVO and a BOSS FV-300L in the FX loop. Both pedals are very good and the BOSS has a tuner output that is very convenient.
ernie ball, ernie balls, expression pedal, volume pedal, volume pedals
