Old 12-20-2008, 10:26 PM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
Vox Valvetronix into tube power amp. hmm
We dig the heck out the the valvetronix when it's not mic'd. But something about the mystery of what you hear, and what comes out of the PA makes the VOX sound like you are mic'ing a radio. Since we like the versatility of the valvetronix and the easy to play tone, we are thinking of running the direct out into a tube power amp into the 4x12 cab. Until I get my hands on an amp, I'm considering running it into the return on the JSX and using that power amp section. Everything is packed up till after Christmas, so i can't try anything till then. Anyone try anything like this?
I used to run my POD2.0 into the return on the Legacy head, and that worked quite well really.
Old 12-21-2008, 01:37 AM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
Re: Vox Valvetronix into tube power amp. hmm
I run my GT-6 into the return of my Valveking with JJ tubs. No probs here and sounds great.
Old 12-21-2008, 07:49 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
I've used my GSP2101 into the FX loop on my JCM900 100W for ten years.
Awesome sound, perfectly controllable. Note that this means I still get to switch channels (and reverb!) on the JCM if necessary, also the presence control is after the FX-loop.
Dunno about the exact routing on the JSX, but it may be similar and some of the controls may still work (IE presence, loose/spongy, reverb etc). If the JSX has a footswitch I suggest you hook that up to check these things.
FS: VHT 2/50/2 power amp and VHT GP3 preamp ALL TUBE sfx70 Classified Ads: Guitars and Gear 2 09-17-2010 09:11 PM
WTT: RG570 for Tube Power Amp Kontalonis Classified Ads: Guitars and Gear 2 08-07-2006 08:16 PM
New Carvin Tube Power Amp? The Dark Wolf Gear and Equipment 10 12-30-2003 06:44 PM
