Old 07-01-2007, 02:24 PM
Amy  is offline
Posts: 164  -  iTrader: (0)
Wa Wa Pedals!! Help!! I need answers!
Hello Everyone,
I really need some help and advice and I hope everyone that reads this message will pass this around:
I keep breaking and wearing out my wa wa pedals!!!
What is the best one on the market and the most durable or should I customize the ones I have with heavy duty parts??????????
I have gone thru two Cry Baby Pedals and an older Vox pedal!!
Last show I did, one crapped out on stage!!!!
Please give me all opinions.
Someone mentioned the Steve Vai Bad Horsey pedal- has anyone tried that one yet???
Thank you so so much for the opinions and help-
Amy Schugar
Old 07-01-2007, 02:28 PM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
Re: Wa Wa Pedals!! Help!! I need answers!
If you dont care what they sould like, the Bad Horsie is ok. I have had both versions and wasn't a fan of them, but they did work fine for years. I just replaced the BH2 with with a Dunlop Crybaby from Hell, and I htink it sounds grea, but you dont seem too happy with the Cry babys. Im a pretty fat bag of crap though, and when I step on something, it stays stepped on and mine hasnt let me down yet, although I've only had it a couple of months.
Old 07-01-2007, 02:33 PM
Amy  is offline
One of the huge problems I get is feed back from my wa wa's and/or "bypass" when I shut them off- I am super confused about what is happening..
when they are working great, all is wonderful! Then, something goes wrong.. does anyone know of anyone to fix the pedals I have in the Bay Area?????
I hope I get a ton of responses from this Thread- I really need help on this wa wa issue-
Thank you for replying-
Old 07-01-2007, 02:36 PM
elcid  is offline
I dont quite understand what you are saying, you get feedback when you use them and when you shut them off? Have you tried putting the wah at a different spot in your chain?
Old 07-01-2007, 02:41 PM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Hey amy
I like my Bad Horsie!! It's been going strong for a good 5 years or so now. (B.H.-1) A lot of people think they do not sound as good (though I think it sounds fine)
But as far as durability, they are probably hard to beat
Old 07-01-2007, 02:46 PM
Amy  is offline
The pedal is running second in the chain.. right after the volume pedal..
I thought this is the way to run it-
Old 07-01-2007, 02:47 PM
I run mine in front of the volume pedal and have no probs
Old 07-01-2007, 02:50 PM
elcid  is offline
Have you tried moving it, just to see. There really isnt a right or wrong place for it.
Old 07-01-2007, 02:55 PM
Amy  is offline
A lot of times, when I step on the pedal, it will bypass my system and shut off everything and I am left standing there with no sound. I always have fresh batteries, so not sure why my pedal would shut off the sound when I step on it..
Then I have a pedal modded and when I step on it , it acts like a boost and gain pedal-
Old 07-01-2007, 02:58 PM
Amy  is offline
I thought I have tried moving the pedal..
aww what a pain in the butt.. I wonder what Joe Satriani uses and how??????????????????
Old 07-01-2007, 03:06 PM
elcid  is offline
So you are going guitar -> wah -> volume pedal, and everything works fine until you step on the wah, then you lose all everything, but this doesnt happen with a new wah, it works fine for a little while first?
Old 07-01-2007, 03:07 PM
elcid  is offline
I I wonder what Joe Satriani uses and how??????????????????
Im sure if you wait a few more months he will put one out with his name and a silly picture drawn on it.
Have you checked guitargeek.com, they may have his setup and how it's layed out posted there.
Old 07-01-2007, 04:31 PM
GilkyBear  is offline
Posts: 4,110  -  iTrader: (16)
I have had my Bad Horsie I for years and it has never let me down. I like it because I really love the fact that it's spring loaded and returns to the off position as soon as you take your foor off of it. I also like the optical switch in it, no potentiometers to wear out. And I am quite happy with the sound of it although I know it is a matter of taste.
Old 07-01-2007, 10:14 PM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
I've own a bad horsie 2 and a JH1 before and have tried the original crybaby, IMO those two blows the BH2 away, but I must admit the BH2 is much easier to use.
Old 07-01-2007, 10:46 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
I had a similar situation like Amy. I tried everything after I decided to get rid of my BH1, and I finally found what I wanted in the VOX Clyde wah.
It is more 'musical' to me than the others plus it has true bypass.
Amy - I suggest you lose the batteries and go with a powered board -you'll be less likely to crash during a show. There are some low-cost powered boards in the Musician's Friend catalog or website....good luck.
amy schugar, dunlop crybaby, expression pedal, joe satriani, morley wah, pedal board, rack setup, steve vai, volume pedal, voodoo lab, voodoo labs
PEDALS? clk102293 Gear and Equipment 27 04-18-2007 01:45 PM
WTB: Pedals kirk Classified Ads: Guitars and Gear 1 03-11-2007 05:32 PM
Digitech 2101 vs G-force vs GCX with pedals ME. Gear and Equipment 11 08-27-2006 05:03 PM
suggestions on pedals? Ibanezer Gear and Equipment 7 10-18-2003 12:10 AM
