Old 08-02-2001, 10:07 AM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
Wah Pedal Problems - How do I make it sound good!?!
I'm having some troubles. *I have a Korg Toneworks AX-1G that I use with my Line6 Flextone II for added modulation effects and pedal effects, esp. wah and pitchbend. *My problem is, when I put the AX-1G before the amp, the wah sounds too light, but if I put it in the effects loop, it gets too heavy of a wah and when rocked all the way back, it muffles the sound almost to the point of being completely inaudible. *I want it just so that I can basically cut off the lower range of the wah pedal. *Any suggestions?
Old 08-09-2001, 06:35 AM
7 Dying Trees  is offline
Posts: 1,708  -  iTrader: (4)
Wah Pedal Problems
I'd just get a seperate wah. i have never managed to find a place in my chain that sounds better than as the first element in the chain. If the wah on your pedal sounds weak, then I'd go out and get a seperate one, something like a vox or a crybaby. I found that vox do really cool ltd edition wah pedals that have an extended range, giving you more wah, and they are cool!
just my thoughts...
wah pedal, wah pedals
