Gear and Equipment
Wall hangers. Recomendations?
Gear and Equipment
01-07-2008, 05:14 AM
jazzedout
Posts: 671 - iTrader: (
I've seen a lot of wall hangers on *bay but I am a little worried of their quality. The two simple things that anyone wants from a wall hanger are not to damage the finish of the guitar and not to fall on the floor from that high.
So... what do you guys use?
jazzedout
Find all posts by jazzedout
01-07-2008, 06:14 AM
DavyH
Posts: 904 - iTrader: (
Re: Wall hangers. Recomendations?
Hercules. The swing arms close over the face of the fretboard as soon as you put downward pressure on the bar, so your guitar isn't falling off in a hurry. They're a bit sticky on the
locking nut
, but you get the knack inside the first try or so.
DavyH
Find all posts by DavyH
01-07-2008, 06:21 AM
SeanB
Posts: 358 - iTrader: (
DavyH
Hercules. The swing arms close over the face of the fretboard as soon as you put downward pressure on the bar, so your guitar isn't falling off in a hurry. They're a bit sticky on the locking nut, but you get the knack inside the first try or so.
That's what they use in my
local music shop
Very good quality hangers.
-Sean
SeanB
Visit SeanB's homepage!
Find all posts by SeanB
01-07-2008, 08:14 AM
shogun
Posts: 1,525 - iTrader: (
if you are going to hang your guitars, you should def make sure you are devoted enough to keep the room at a proper temperature and humidity level.
shogun
Visit shogun's homepage!
Find all posts by shogun
01-07-2008, 08:42 AM
heffergm
Posts: 230 - iTrader: (
shogun
Assuming you keep your guitar, in the case, in the same room you're going to hang it, how could it possibly make a difference? If the case has been in the same room for any length of time, it's going to have the same relative humidity as the rest of the room.
I use Hercules hangers.
The important thing I'd suggest is absolutely do NOT use them unless you're going to run to the hardware store, get some long drywall screws, and find a stud to screw them into. There's no way I'd trust any drywall anchors to hold my guitar in the wall.
heffergm
Find all posts by heffergm
01-07-2008, 09:24 AM
Tank
Posts: 926 - iTrader: (
Reviews: 65
+1 to Hercules!
And yes have them really really secured in your wall...
Tank
Find all posts by Tank
01-07-2008, 09:38 AM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Hercules are good wall hangers. The sheet rock anchors they come with suck, so I'd go get some better ones from the hardware store, or even better, try to mount them in studs.
jaxadam
Find all posts by jaxadam
01-07-2008, 11:12 AM
kennydoe
Posts: 3,416 - iTrader: (
I bought a bunch of "string swing" hangers and put them up a couple of weeks ago - just make sure you mount them in the studs and they'll never fall.
kennydoe
Visit kennydoe's homepage!
Find all posts by kennydoe
01-07-2008, 11:27 AM
albee1952
Posts: 784 - iTrader: (
Another vote for the String Swing but I wouldn't sweat finding a stud. Just use the large drywa;; anchor that comes with it or go to home depot and get a little box of them. I have never had one come out of the wall in 10 years.
albee1952
Find all posts by albee1952
01-07-2008, 12:01 PM
kennydoe
albee1952
I agree - if a stud isn't available, use an anchor FAR bigger and stronger than you'll think you'll ever need. It's a little extra money, but not as much as fixing a guitar that fell off the wall.
Make sure you get the 'molly' type that you push thru the wall and it ends up behind the wall at least a couple of inches on both sides.
kennydoe
01-07-2008, 01:33 PM
Drew
Posts: 4,538 - iTrader: (
DavyH
I tried Hercules hangers years ago. I've currently got three sitting in a bag in my closet, with three String Swings hanging guitars on my wall.
Part of it was they just always felt kind of cheap and gimmicky, but a large part of it is that while they WILL just barely accomodate a seven string locking nut, it's a tight squeeze and I've almost dropped guitars when they unexpectedly caught on the hanger while trying to disengage them.
The String Swings meanwhile are more attractive, way simpler, more elegant, and accomodate a seven string neck with ease.
I'm not too worried about them falling out of the wall either, considering they're hanging over my bed.
Drew
Visit Drew's homepage!
Find all posts by Drew
01-07-2008, 01:38 PM
gitarguy
Posts: 377 - iTrader: (
kennydoe
I use string swings also, never had a problem with just the sheet rock screws they come with. No studs needed.
Kennydoe, what did you use to get the Fly to hang?
gitarguy
Find all posts by gitarguy
01-07-2008, 03:04 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
+1 on the String Swing wallhangers. I've got 5 on my wall and none of them are mounted on studs. This is an old picture:
I used metal wall anchors which support 15 lbs each. Seeing as there are 2 holes with the String Swing hangers, I could easily put a
les paul
and there shouldn't be a problem.
Jimmy
P.S.: Another plus for the String Swing mounts is that the yoke pivots are adjustable and you can easily open them wider if you have a wider neck on your guitar.
jb4674
Find all posts by jb4674
01-07-2008, 03:55 PM
kennydoe
jb4674
wow...either that's a really high ceiling, a really short couch, or those are very tiny guitars.
gitarguy
My Fly came with a little molded plastic doo-hickey specifically for that purpose. It mounts on the tuners of the guitar (floating, not screwed in or anything) and has a cut out for the guitar holder. I'll take a pic if you're really interested.
kennydoe
01-07-2008, 04:45 PM
gitarguy
kennydoe
If you don't mind, I would like to see it. Maybe I can get mine off the floor.
gitarguy
guitar shop
les paul
local music shop
locking nut
string bass
string lock
how to make guitar hangers
how do i hang gutiars on a wall
how to make a guitar wall case
Wall hangers and storage.
Clydefrog
Gear and Equipment
11:16 PM
Wall Hangers
tTz
Gear and Equipment
07:21 PM
wall hanger's, good or bad?
jessecruzastoria
05:25 PM
How to hang guitars on a wall HORIZONTALLY?
TAorama
Gear and Equipment
09:31 PM
Guitar wall hangars (several guitars on one wall) - suggesti
jemsite
Gear and Equipment
12:42 PM
01:32 PM
