Gear and Equipment
What are your delay and/or reverb settings?
Gear and Equipment
11-14-2001, 04:54 PM
pri0531
Posts: 622 - iTrader: (
Just curious.
Out,
GP
pri0531
Find all posts by pri0531
11-14-2001, 05:25 PM
jeffrey
Posts: 971 - iTrader: (
Wow that's an ambiguous question.
I use reverb and delay sometimes, but I have no idea how to answer this question hehhee.
Keep in mind too, it's going to be different answers from everyone unless we all use the same processor.
jeffrey
Visit jeffrey's homepage!
Find all posts by jeffrey
11-14-2001, 05:44 PM
pri0531
You r correct it is pretty ambiguous (sorry about that). *I was looking for generalities. *I use a midiverb 4 for those effects and was curious see other peoples settings for the delay (i.e. time / ms, feedback controls, level, panning, and high/low frequency equalization). *For reverb the density parameter, diffusion, high and low frequency damping, hold and release times would be pertinent.
Out,
GP
PS: *I should have this in the title *
* * * * * DELAY AND REVERB SETTINGS FOR LEAD GUITAR
(Edited by pri0531 at 4:55 pm on Nov. 14, 2001)
(Edited by pri0531 at 4:56 pm on Nov. 14, 2001)
(Edited by pri0531 at 4:57 pm on Nov. 14, 2001)
pri0531
11-14-2001, 07:23 PM
jeffrey
Hehe, I'll see what I have setup in my TC M-One when I get home.
jeffrey
11-15-2001, 01:12 AM
jem7vwh
Posts: 1,583 - iTrader: (
Reviews: 4
I run two delays and one reverb when I'm working lead in my church's band (where I'm trying to blend in and just play pretty solos).
Those settings are as follows
Delay 1: *Boss Digital Delay
Level: 4.5
Feedback: 4
Delay: 320 ms
Delay 2: *DOD Digital Delay
Level: 5
Feedback: 4
Delay: 360 ms
Reverb: *DOD FX9 Processor
Type: Arena
Level: 9
The three of these combined give me kind of a U2 cascading delay feel.
jem7vwh
Visit jem7vwh's homepage!
Find all posts by jem7vwh
11-15-2001, 05:56 AM
nuno
Posts: 4,725 - iTrader: (
Sorry pri0531,
I know it has nothing to do with your question but... would you put an eye to my post 'Jemsite Users Nicknames' in 'Off topic/Miscellaneous' section? Your nickname is pretty curious!
Answering your question, I use a DD-5 for a slight slapback just here & there. If you read my nickname, you'll understand why.
nuno
nuno
Visit nuno's homepage!
Find all posts by nuno
11-15-2001, 06:04 AM
Devo
Posts: 1,483 - iTrader: (
My lead setting on the legacy varies,
I have it off at 6.5, 6.5, 3-5, 7, 8 (P T M B G)
I have it on about two or three (6, 6.5, 6, 6.5, 8.5)
basically the lower the mids the less verb I use.
then on the clean channel I use it any where up to about six,
dunno what levels my pedals are at but Ill check em out.
Steve
(Edited by Devo at 11:22 am on Nov. 15, 2001)
Devo
Find all posts by Devo
11-15-2001, 10:40 AM
pri0531
Thanks for the input guyz. *Devo - It seems that we have close to the same
amp settings
. *Have you tried a
sonic maximizer
on the carvin? *It wakes it up -Big Time.
Out,
GP *
pri0531
11-15-2001, 10:50 AM
Devo
being young and naive I have never even heard of a sonic maximizer?
can you fill me in?
Steve
Devo
11-15-2001, 11:02 AM
pri0531
Here u go. This is description of the unit. *It is a very economical unit (I believe around $120.00 - $140.00)
Out,
GP
http://www.bbesound.com/frameset.htm
(Edited by pri0531 at 10:05 am on Nov. 15, 2001)
pri0531
11-15-2001, 11:21 AM
ripl3y
Posts: 747 - iTrader: (
I turn the knob on my Delay to about 1/4 and it seems to be quite sufficent :biggrin:
Steve
ripl3y
Find all posts by ripl3y
11-15-2001, 11:32 AM
ripl3y
Obviously as you can see by my last post I have a pretty basic delay unit
I'm looking to upgrade, but as I'm not too fussy I want a CHEAP but bang for buck (or pound) rack unit.
I don't want it to do 83.75 different effects, just a neatly controllable delay.
Any suggestions guys/gals?
Thanks
Steve
ripl3y
11-15-2001, 11:49 AM
pri0531
I am satisfied with my
Alesis Midiverb
4. *I believe it was around $220.00 USD (several years ago). *They may be cheaper now. *It is rather user friendly.
Out,
GP *
pri0531
11-15-2001, 02:26 PM
Devo
interesting....... but I cant figure out what it does...... must be my blonde hair.
seems to be just a noise reducing tool ?!?!
is it a signal booster too?
Ill see if my local guitar store has one.
Thanks for the tip
Steve
ps what are your favourite legacy settings for which guitar/pickup?
Devo
11-15-2001, 03:16 PM
pri0531
The Sonic Max basically separates the lows, mids and highs. *It really helps to fine tune the eq. *The low contour feature helps define the lows.
The settings for the Legacy with my VWH are Gain 8.5, Bass 6, mids 5.5, and treble 5.5. *I generally keep the settings as mentioned with my UV777PBK with the exception of the bass. *I lower it a bit to 5. *
The clean channel is close to your settings.
Out,
GP
pri0531
alesis midiverb
amp settings
bbe sonic
bbe sonic maximizer
boss digital delay
sonic maximizer
how much delay to use for solos
how to boss ds settings
trem before reverb?
lin6 share you settings
what are resonance and presence amp settings
04:52 AM
