Gear and Equipment
WHat happens when you put a bridge pickup in the neck position?
Gear and Equipment
12-07-2007, 01:37 AM
bdk
Posts: 278 - iTrader: (
Just curious, really don't know...
bdk
Find all posts by bdk
12-07-2007, 02:30 AM
Triggerman9
Posts: 88 - iTrader: (
Re: WHat happens when you put a bridge pickup in the neck position?
in my experience... overly bassy and loud, but not really clear and amped up like you'd expect... better to stick with a hot neck p/u IMHO
Triggerman9
Find all posts by Triggerman9
12-07-2007, 02:38 AM
Martyr Machine
Posts: 340 - iTrader: (
The world ends.
Nothing happens. Pickups specifically designed for the bridge have a higher output to compensate for the lesser string vibration. You don't want a
neck pickup
with a higher output than the bridge because you generally get a huge volume difference when switching positions.
Martyr Machine
Find all posts by Martyr Machine
12-07-2007, 03:04 AM
reguv760
Posts: 1,197 - iTrader: (
Reviews: 12
I'm one of those guys that experimented such a feat... I installed a
Blaze Bridge
in the neck on my UVGR thinking I was going to get the same tone as the Blaze Neck with higher output for sustain...
just like Triggerman said, it ended up being bassy. The scooped mids sounds great on the high register except the low notes sounds way too muffled... there's no volume difference between the neck and bridge [which is an Evo7] but it's cause I lowered the neck p/u; it's near-level with the Blaze single.
... still waiting to get a D-Activator7 neck... I might get rid of the Blaze soon but I might want to try putting it back in the
bridge position
before I do that.
Another lesson learned :P
Reg
reguv760
Visit reguv760's homepage!
Find all posts by reguv760
12-07-2007, 03:40 AM
jazzedout
Posts: 671 - iTrader: (
I have a Dimarzio Fred in the
neck position
of my RG550 with a
Tone Zone
in the bridge. I really like the sound of it!! I did it as an experiment at first, but it has stayed there for many years. The output is just right, not to bassy as you say, but maybe this is because the Tone zone has more output. The single coil mode is really sweet sounding as well.
jazzedout
Find all posts by jazzedout
12-07-2007, 05:21 AM
RSVampire
Posts: 1,813 - iTrader: (
like other statements here... the pickup will generally get more bassy or muddy and end up with higher output so you'll need to find an even higher output bridge model to allow proper levels between the two.
there are some cases where people will enjoy their
bridge pickup
in the neck, sometimes it fits the players and their settings and other times it doesn't.
I'd say if you're really curious, just stick the pickup in the neck and see how it sounds... not really gunna hurt anything or cost anything.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
12-07-2007, 03:01 PM
Jaden
Posts: 2,464 - iTrader: (
I have a tone zone in the neck of my 450 - its OK if you have the same pickup in the bridge but then wire the neck in parallel instead of series.
sounds good depending on what you play really.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
12-08-2007, 03:48 AM
bdk
Thanks fellas. I think I'll just sell one of my extra pickups online and buy the proper neck pickup.
bdk
12-08-2007, 04:33 AM
IbanezFreak777
Posts: 3,487 - iTrader: (
Reviews: 24
Dimarzio states on their website, that any
pickup combo
will be fine as long as the neck pickup output is not higher than the bridge pickup output.
IbanezFreak777
Visit IbanezFreak777's homepage!
Find all posts by IbanezFreak777
12-10-2007, 06:58 AM
casper777
Posts: 331 - iTrader: (
You're right Jazzedout.. FRED works for both position and is sounding particularly great in the neck position...
I have one in my J Custom RG Gear and it's my prefered neck pickup since.... even better than the great
Air Norton
Many pickups work for both positions..
PAF Pro
for exemple... FRED...
casper777
Visit casper777's homepage!
Find all posts by casper777
12-13-2007, 04:00 AM
reguv760
Reviews: 12
... as an experiment, I moved the Evo7 from the bridge to the neck an hour ago and to my suprise, it's not bassy! Just loud and in your face for a neck p/u...
holy #!% why hasn't anyone done this before?
Reg
reguv760
12-13-2007, 08:52 AM
IbanezFreak777
Reviews: 24
I'm sure your not the first.....
IbanezFreak777
12-13-2007, 09:32 AM
Ibateur
Posts: 2,951 - iTrader: (
jimmyj has put a ToneZone in the neck of his blue guitar I think and it sounds quite good. Look him up on Youtube and here in the boards.
Ibateur
Find all posts by Ibateur
air norton
blaze bridge
blaze neck
bridge pickup
bridge position
coil mode
neck pickup
neck position
paf pro
pickup combo
scooped mids
tone zone
does the JEM 7 trem stay in position?
how do u measure a bridge
parker are they neck thru
GT 12ax7M in what position
what is best neck pickup
Seymour Duncan neck pickup good with X2N on bridge
_MKK_
Pickups & wiring
04:19 AM
S1625 Pickup Query: Evo's in neck and Tone Zones in bridge
Arivergandez
02:05 AM
Pickup orientation
hittman7
Pickups & wiring
10:40 AM
an evo Neck in the bridge position???
simonargento
12:48 PM
Breed bridge PU: describing the mids
Ced777
Pickups & wiring
05:49 PM
05:18 PM
