Gear and Equipment
What speaker cables are you using???
Gear and Equipment
Page 1 of 3
02-19-2003, 12:10 AM
SliderJeff
Posts: 134 - iTrader: (
Hey guys,
I am considering going down the
power amp
and 4x12 cabinet path and I would like to know what brand/model/whatever you are using to connect your head or power amp to your cab. I am a TOTAL newbie when it comes to connecting these things... the only thing I know is that it has to be SPEAKER CABLE and nothing else that is used. Also, are the ends of the cables just normal 1/4" phone plugs or something different? Do you buy the speaker cables with these already attached or do you solder them yourself. While I am competent with a soldering iron, I don't LIKE soldering... so if you have recommendations on presoldered (if it needs it) speaker cables... please lay it on me.
Thanks,
Jeff
SliderJeff
Find all posts by SliderJeff
02-19-2003, 12:11 AM
jemsite
Administrator
Posts: 9,271 - iTrader: (
use unshielded cable w/ 1/4" ends to connect a head and cab... glen
jemsite
Find all posts by jemsite
02-19-2003, 12:13 AM
Mandrak
Posts: 440 - iTrader: (
LiveWires. Went to NY to buy´em because "speaker cables" don´t exist in Brazil...
Mandrak
Find all posts by Mandrak
02-19-2003, 02:12 AM
musicdr
Posts: 671 - iTrader: (
I'm using
monster cable
,but any good quality cable should do the trick.
musicdr
Find all posts by musicdr
02-19-2003, 03:13 AM
jonrayl
Posts: 110 - iTrader: (
Monster, monster, monster......
theyre a bit more expensive.... but how much did you spend on your rig? I got about 3 grand worth of gear in my rack and cabs, why lose all that using $10 cables?
Besides, they have the best warrenty in the biz, and it covers the gear its connected to. As the guy from the company told me, "You can hang your wife with it, we'll replace it."
jonrayl
Visit jonrayl's homepage!
Find all posts by jonrayl
02-19-2003, 10:03 AM
Gabe Nickelson
Posts: 961 - iTrader: (
jemsite
I always thought unshielded cables could pickup noise? I had a cheap Radio Shack cable going from my Mashall head to 2 4x12 cabs. I was getting noise. I bought Monster cables (500 series) and haven't had any noise...
I use all monsters. A really good quality guitar cable may run you $30 or more, but it's worth it. Hell, even my 6ft patch cables retailed for $19.95.
Gabe
Gabe Nickelson
Visit Gabe Nickelson's homepage!
Find all posts by Gabe Nickelson
02-19-2003, 10:18 AM
goldboy
Posts: 170 - iTrader: (
Monster Cables.....
BLOW ASS CHUNKS....
They're good quality...not for their price.
I guess if you need 'one' cable or just a couple for the small spots...sure...go ahead and spend the dough. However, if you're planning on buying more than a couple...make your own.
As far as speaker wire is concerned:
www.partsexpress.com
16 Gauge Oxygen Free Cable (30 ft = $10.00)
Jumbo 1/4" Plugs (each $1.15)
You can custom make your length and it'll sound excellent. As far as shielding is concerned, if you're that worried about it OR if you are in an area that is highly receptive to RF noise, then just get some shielded cable...a 3ft. run is still about $1.00.
Monster cable for speakers and patches are okay...guitar cable...blows.
goldboy
Find all posts by goldboy
02-19-2003, 12:28 PM
JESTER700
Posts: 2,234 - iTrader: (
I'm with you, goldboy - roll your own. It's all about gauge, people. Any fancy "monster talk" is marketing.
JESTER700
Find all posts by JESTER700
02-19-2003, 12:59 PM
SliderJeff
Ok... so if I am gonna "roll my own" and I snag some 14 AWG 2 conductor speaker wire, what is the proper way to solder the wire to the Switchcraft #280 connector?
Thanks,
Jeff
SliderJeff
02-19-2003, 01:06 PM
jemsite
Administrator
now is a good time to ask... can anyone recommend any SOLDERLESS connectors aside from George L?
jemsite
02-19-2003, 01:18 PM
SliderJeff
jemsite
Glen,
Doesn't your question imply solderless wire... of which I thought George L was the only brand? Or do you already have the George L cable and want another make of connector? Sorry if this is a dumb question... it was just my understanding that the George L stuff was constructed with the core of the wire being a conductor with the ground being elsewhere and the connector doing a "pierce" the wire to form the connection sorta thing.
Later,
Jeff
SliderJeff
02-19-2003, 01:30 PM
jemsite
Administrator
many premium audio connectors are "crimp/compression" style (ie. decent banana connectors - ala george l.) the wire itself is not an issue IMHO, it's getting a firm connection to the connector. it's all twisted and unshielded, just varying grades of soft metal.
I've seen permanent "solderless" crimp connectors for RCA and other plugs, but not 1/4 on that site. I dont see how soldering would benefit sound conduction there myself since the contact mass might be *more* with a compression connector? ...glen
jemsite
02-19-2003, 03:51 PM
JESTER700
And in any case, it's almost impossible for contact mass to be LESS than that of the 1/4" connector and the jack! These things truly suck, and we should all start using bananas or speakons.
I dunno where to get solderless 1/4". Soldering isn't hard.
JESTER700
02-19-2003, 04:20 PM
jonrayl
Re: Monster Cables.....
goldboy
As far as shielding is concerned, if you're that worried about it OR if you are in an area that is highly receptive to RF noise, then just get some shielded cable....
Do NOT use shielded cable for speakers... you could blow an output transformer.
jonrayl
02-19-2003, 05:46 PM
nocebo
Posts: 56 - iTrader: (
re
while we're on the subject, in the parts express catalog, there is a brand called Carol, who makes something called Heavy Duty SJ Power Cable.
says it's good for speaker cable. but i don't see 'unshielded' anywhere. how do i know what i'm looking at, and what's another brand of speaker cable for this use?
these don't have any ends, by the way, i'd put my own on.
colin
nocebo
Find all posts by nocebo
Page 1 of 3
amp head
bbe sonic
bbe sonic maximizer
death metal
input jacks
mesa boogie
monster cable
monster instrument cables
power amp
ricky garcia
sonic maximizer
speaker cab
warmest celestion speaker?
how to build a speaker cabinet
if my clip is on too long what happens to my speaker
how to parallel speaker cabinets
18ga for speaker cab?
05:23 PM
