Old 06-07-2002, 09:37 AM
Mr Orange  is offline
Posts: 448  -  iTrader: (0)
Will it FRY?
My amp's got two speaker outputs, 4 ohm and 8 ohm.
I know it's ok to use an 8 ohm cab with the 4 ohm out, but would it fry my amp to use an 8 ohm (1x12) in the 8 ohm out and another 8 ohm (1x12) in the 4 ohm out simultaneously?
Suggestions appreciated.
Thanks.
Old 06-07-2002, 10:21 AM
bammbamm  is offline
No, you will be fine.
If you go LOWER than the listed impedence on your amp, then you run the risk of damaging your output transfer. Equal or greater than is fine.
Bamm
Old 06-07-2002, 11:19 AM
Gresh  is offline
Posts: 1,416  -  iTrader: (10)
bam is right. You will be fine. Plug it in and let 'er rip.
Old 06-07-2002, 11:23 AM
Thanks guys! :P
ohm cab
