Old 08-23-2006, 05:44 PM
ShredHead42  is offline
Posts: 344  -  iTrader: (0)
will this power supply work w/ this pedal?
i have an adapter that says:
class 2 transformer (is it a robot in disguise?)
input - ac120V 60Hz 8W
output - dc9v 300mA
and then i got a cheap behringer delay pedal that says the power supply should be:
9v, 100mA DC regulated.
Will it supply power for my pedal or will it fry it? I obviously don't know much about electricity and wiring.
thanks in advance!
Old 08-24-2006, 10:10 AM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: will this power supply work w/ this pedal?
yes, im pretty sure that class 2 is regulated DC supply. it should supply that pedal with no problem.
I will power the pedal although some PSU's will create electrical noise, if you find that your rig is noisy after using it, it could be the PSU.
Old 08-24-2006, 11:21 AM
Lefty Robb  is offline
I don't think its a good idea to give the pedal 3x the amp rating its asking for.
Old 08-24-2006, 02:20 PM
Jaden  is offline
the pedal will only take what it needs !
working on that theory, every time you plug your TV in to a 32A main - the TV will suck up 32A and go BANG...
it dont work like that..
Shredhead... you'll be fine.
Old 08-24-2006, 02:30 PM
Distantshore  is offline
Posts: 3,671  -  iTrader: (0)
Images: 4
Old 10-31-2006, 06:19 AM
W0MB13  is offline
Posts: 91  -  iTrader: (0)
But what if you were to use a 300ma powersupply that was unregulated..?
Old 10-31-2006, 07:23 AM
jimmyfingersminion  is offline
Posts: 219  -  iTrader: (2)
it would still be fine, just 'inconsistently' powered ie. relatively noise prone
Old 10-31-2006, 08:51 AM
exactly, TVs have built in voltage regulators and power supplys so they can take what they need.
Old 11-01-2006, 05:57 AM
W0MB13  is offline
So assuming you had a 1amp power supply, if it was regulated you would have no problem powering pedals without noise.
Old 11-01-2006, 05:58 AM
yes. that would be fine
delay pedal
FS: Voodoo Labs Pedal Power 2 chronicinsomnia Classified Ads: Guitars and Gear 0 11-04-2005 06:57 PM
Looking for pedal board Jemwielder Gear and Equipment 13 10-31-2005 07:42 PM
Pedal Board Design? Cycovision Gear and Equipment 23 03-16-2003 01:03 PM
Possibly the best pedal I've ever owned jay ratkowski Gear and Equipment 31 08-02-2001 03:54 PM
Expression Pedal? - which volume pedal will work? mikek Gear and Equipment 1 01-02-2001 08:39 PM
