Old 04-21-2008, 08:43 PM
texshred777  is offline
Posts: 681  -  iTrader: (2)
Reviews: 3
Re: Your string guages are wrong!
I'd give them a shot, they couldn't be any more expensive than the $30 I spent for my last set. But, do I have to complete an audition to prove my 'worthiness' to have properly gauged strings?
Old 04-21-2008, 09:35 PM
Dino  is offline
Posts: 1,721  -  iTrader: (2)
No, lesser players are allowed to buy strings...
Old 04-21-2008, 10:46 PM
CaptainD00M  is offline
Posts: 144  -  iTrader: (0)
I'd like what the guy has to say a whole lot more if he didnt confront you with:
1: A spoilt Childs attitude. I mean i appreciate that you have had to put a lot of work into your theory, but thats no need to go off and start calling people who have jumped on your gravy train usless and other childish names.
It detracts from your message.
If its ment to stand tall it will, you dont need to tell people that in order to get credit.
2: If he didnt use so many dam colours.
3: if he set out the String Gauge page in a more user friendly pattern, and cut down on the textual felatio about his idea.
Still good idea and worth investigating... just reminds me all to much of tr00ness discussions about metal.
But what do i know?
Old 04-22-2008, 07:21 PM
kool98769  is offline
Posts: 37  -  iTrader: (0)
Originally Posted by Kemono View Post
Best thing is 10's in Eb. The tension is progressively lighter in a pretty even manner. Thicker sound. Longer lasting. Progressive tension from E - E.
For 9's you can do what I do and use a 11.5 for the b.
If you tune down and try and use the Zachary custom zoggs or whatever their called, the tension would not be as designed; it would be off. It's possible to figure out on Di'Addario strings' website.
How would it be off? You're decreasing the tension on all the strings uniformly. It wont be the same tension number, but it will still be ratio'd the way it was intended. And 10's in Eb is NOT progressively lighter. It will stay proportionate to the way it was in E regular, and zachary clearly said 10's in E were not right.
Old 04-24-2008, 01:53 PM
Dino  is offline
Yes, tuning down to Eb won't change the way the strings relate to each other. You are lowering the tension, but if it was off to begin with tuning down to Eb won't help any.
Old 04-24-2008, 02:08 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Originally Posted by Dino View Post
Been using these strings for almost a year now. Still love them... I think this theory is sound. Anyone else try them yet?
Ok, was there REALLY any need to bump a one year old thread to flame the controversy a bit further? Does this Zachary character pay you to plug his stuff, or was whatever your previous religion just no longer cutting it for you?
Seriously, man, I'm getting a bit sick of seeing this guy's closed-minded "everyone but me is wrong!" drivel around here.
Old 04-24-2008, 02:46 PM
Dino  is offline
I don't get paid to say anything. I just like playing on strings that are designed with the tension taken into consideration. It is an interesting discussion for those of us who care about how the guitar funtions as an instrument.
Old 05-04-2008, 02:22 PM
Kemono  is offline
Posts: 157  -  iTrader: (0)
That may be true, and it seems like it would be true though I don't know because I can't actually measure the tension.
This chart didn't really make any sense to me:
http://www.daddariostrings.com/Resou...sion_chart.pdf
So I emailed D'Addario about getting strings for a guitar in Eb. I went back and forth with brian johnson trying to find the right strings and it said a 13 on the b would be too much tension, so I went with a 12, which is basically the stock set of 10-42.
I feel like I remember reading an email where he wrote the tension for each string for 10's in Eb, but can't find it.
So it seems like I'm wrong on this one. I'm still much happier with 10's in Eb. I just don't know what the tension is.
Old 05-04-2008, 02:36 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
With 9's, you might be better off with a 12 for the B. Also a 44 for the E. This is as close as you'll get to a progressively tensioned set. 11.5 isn't quite heavy enough. In fact, even a 12 is still lower tension than the 9 (13.13 vs 13.11 pounds) but it feels fine.
http://www.jemsite.com/forums/f21/st...rts-73846.html
Old 05-04-2008, 02:49 PM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
It's not that bad, and the guy has a sense of humor about it. My only problem is he doesnt seem to understand that everyone but ME is wrong.
In conclusion one could start a thread that Everything Dino knows about El Cid is wrong.
Old 05-05-2008, 01:07 AM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
I can't believe this thread hasn't been closed yet! Such controversy.
I only use 2 springs on my OFR. As it should be. What does that do with string tension?
Old 05-05-2008, 12:18 PM
Dino  is offline
The strings would have to be at the same tension as with three springs in order to be at the same pitch. The two springs would just have to be adjusted tighter. I hear you get a more responsive feel from your trem, though.
Old 05-05-2008, 01:54 PM
Darin  is offline
2 springs can balance the tension. You get way more flutter, even from just picking a string hard. Some people may not like that. but it's very cool to me. I don't like a stiff trem at all. If you want stiff, stick with hard tail. Still, I have used Boomer 9s since highschool in the early 80s and still do. They just feel like home.
Old 05-05-2008, 07:34 PM
Drew  is offline
I care loads about how the guitar functions as an instrument, enough in fact to know that there is no one RIGHT way for it to function. Thanks all the same.
Interesting idea. For example, i know you know someone who mixes a mean caucasian.
whats string guages does the rg1527 come with nabeelm Other 7-string Guitars 2 06-10-2004 07:05 PM
String breakage with piezo saddles... Pesso Tech: Setup, Repairs and Mods 10 05-04-2004 11:44 AM
String Action, Pickup Height, Neck Bow, etc. Drache713 Tech: Setup, Repairs and Mods 4 11-10-2002 04:46 PM
Jem7VWH GROSS STRING BREAKAGE problems YngVaiTriani JEM and Universe Guitars 37 11-08-2002 07:44 PM
String skipping 101 - ok, I'm bored, lets get started littlegreenman Guitar Lessons & Music Theory 3 06-16-2001 12:31 AM
