Gear and Equipment
Zoom G9 2tt multi-effects
Gear and Equipment
01-21-2008, 06:19 PM
modulo
Posts: 133 - iTrader: (
Hi!!
What do you guys think about the Zoom G92tt multi-effects ?
Some of you probably have it, What about the construction, Is ti road proof??? The sounds of the dual 12ax7 tubes. Is it worth it???
Do you have great patches?? I own a Digitech rp 250 and i'm thinking of buying this unit as a replacement for stage use of the Rp250!!
Is there a site for patches on the net like the Digitech sound community??
Thanks
modulo
Visit modulo's homepage!
Find all posts by modulo
01-21-2008, 06:32 PM
bluealien
Posts: 959 - iTrader: (
Re: Zoom G9 2tt multi-effects
I just recently got one (2 weeks ago), and Im very impressed with it so far. There is only a few site that have extra patches which are great. Once you get the hang of how it works and the setup you will not be disappointed.
I am running this thru a Mesa
tube power amp
, I have not tried to run it thru my Marshall Lead Combo (all solid state) to see if I like it that way.
It seems to be build pretty well, but I have read some issues with the pedals, but it has not happened to me yet.
One thing I do not like is the 2 tubes (Accelerator & Boost) are only set on the board and do not change based on patches, but I think I found my standard sweet spot.
Also there is a PC library, but you have to us MIDI, and only does full dumps, not single updates.
hope this helps a bit
Patch Sites:
http://giasso.s42.eatj.com/
http://groups.google.com/group/zoom-g92tt-patch-bank
http://forum.thestompbox.net/http://www.jemsite.com/forums/f18/
bluealien
Visit bluealien's homepage!
Find all posts by bluealien
01-21-2008, 06:55 PM
T.B.A.
Posts: 135 - iTrader: (
Guys, remember you can change all your settings and save them via this much simpler way (for me anyway, as I can't stand those little screens!)
http://i147.photobucket.com/albums/r290/v-comp/Rack.jpg
T.B.A.
Find all posts by T.B.A.
01-21-2008, 07:04 PM
bluealien
T.B.A.
Are you able to do a live change with the Pedal & PC software? I only been able to do dumps - so im only can modify the pedal on the fly not use the software to.
bluealien
01-21-2008, 07:20 PM
T.B.A.
You can save and adjust everything in realtime from the "effects rack" screen.
Sounds like you're having problems?
T.B.A.
01-21-2008, 07:26 PM
bluealien
T.B.A.
Ok, Yea I had a issue with Midi Drivers, which I just corrected this weekend when I was messing with recording and my Keyboard. I had another M-Audio driver for a
Midi Controller
install, and I think it conflicting with other stuff I had installed. I will test again tonight as removed the other Midi Drivers and only have my correct drivers for my sound card & midi devises now
bluealien
01-21-2008, 09:50 PM
modulo
THANKS GUYS
You made me choose, i will buy the Zoom, even if issues happened with it, you convinced me!!
Any choosen pedals have issues anyway!
if you have a good marshall sound or good patches, send to me by PM
Thanks
modulo
01-21-2008, 11:46 PM
LonePhantom
Posts: 5,368 - iTrader: (
Reviews: 98
I've got a Zoom G7.1ut, but it should translate fairly similarly. I love the JCM 800 amp sim, crank it and add some compression and boost, and it really rips. Make sure you play with that sim if you like the Marshall sound when you get your Zoom.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
01-22-2008, 10:00 AM
richard1973
Posts: 957 - iTrader: (
Reviews: 10
yeah the G9 2tt is a cool unit, a bit complicated for my liking and probably too many options but i have made some very nice sound set ups with it. The unit is sturdy and is a solid piece of kit made from metal (unlike the old old zoom boards).
Only downside is the software, i downloaded the official one so I can edit patches via pc, but the software i downloaded wont install, i just get an error pop up message when i try to run it. (Using XP SP2).
So i have to do everything manually
richard1973
Visit richard1973's homepage!
Find all posts by richard1973
01-22-2008, 11:41 AM
Scali
Posts: 570 - iTrader: (
It's built like a tank. The sound quality is excellent... The factory patches aren't that great, but the unit is easy to edit, so you should have some good tones in no time.
Scali
Visit Scali's homepage!
Find all posts by Scali
01-22-2008, 11:55 AM
bluealien
richard1973
Do you have the .Net Framework installed on your PC? It needs it to run.
bluealien
01-22-2008, 08:08 PM
richard1973
Reviews: 10
blue alien, ah come to think of it no I dont have that installed since i reformatted pc a few month ago.
cheers, i'll look into getting that back on.
richard1973
01-24-2008, 09:19 PM
modulo
HI!!
Just bought the unit!!!!YEA!!!!
Sound great here and at the store!!
Now learnong how to use it!!
Do anyone install the 50 additioal patches from Zoom website??
Is it worth it??
and bought the M-Audio Uno usb/midi port device.
Modulo
modulo
01-24-2008, 09:38 PM
LonePhantom
Reviews: 98
congratulations on the purchase, hope it inspires you with great sounds.
The additional patches are crappy, just like the ones on the unit when shipped. It's not worth it.
LonePhantom
01-27-2008, 03:31 PM
modulo
Does anyone tried it with a
marshall valvestate
poweramp??
Best setting please!!
I have a
Peavey Bandit
112 amp and valvestate poweramp.
Modulo
modulo
marshall valvestate
midi controller
peavey bandit
power amp
tube power amp
vox tonelab
what is a multi-radius guitar neck
what effects is there in whispering a prayer
peavey bandit 112 effects loop problem?
what effects steve vai uses
how to multi colour paint your guitar
Looking for a new Multi Effects
bluealien
Gear and Equipment
33
01-30-2008
06:33 PM
BOSS and Line 6 and Zoom Multi effects units/pedals
mfergel
06:13 AM
Multi effects: Boss vs Digitech
Ali___
Gear and Equipment
06:36 AM
best multi effects pedal?
Drache713
Gear and Equipment
04:46 AM
03:31 PM
