yeah. ignore it.
what's happening is this; when you play back a loop, it's tempo-shifted to match the current project tempo. If the project tempo happens to be slower than the loop tempo, there's going to be a lot of digital artifacts introduced.
Check it this way- when you play the loop, it'll list the original loop key and tempo. using a blank project, set the project key and tempo to match that of the loop. It should play back flawlessly.
-D
