Old 12-07-2002, 08:31 PM
Jeff  is offline
Posts: 1,501  -  iTrader: (1)
Acid Pro
I just had a few general questions about this program...
Is it restricted to just making MIDI tracks, or can I record my guitar with it?
Any good free tutorials on the net for it?
Old 12-08-2002, 01:06 AM
vwall  is offline
Posts: 743  -  iTrader: (0)
I dont recommend using acid for a finishing recording. The record feature is good to help you lay out and test the drum tracks you've written but thats it.. unless you have a $500 sound card.....
As far as Acid for midi
Thats craziness to me...
I hate the way midi sounds.
save all your sessions as the standard acid file and then when you complete a full drum track of your song, go to file, save as, and select wav.
this way you can import the drums to just about any recording software available.
heres what i do:
write the drums in acid, record guitar and bass in acid as test tracks on;y to make sure the timing is all correct..
save entire session as an acid file.
re open that file, delete all but the drum tracks and click save as WAV.
now you have your Acid file with all the tests etc and you have a seperate WAV file with only the drums.
(acid can still play it as a wav)
Then I open up Cool Edit Pro,
import the WAv drum file and record guitars, bass, keys vocals whatever.
Mix, Eq, master whatever and mix it down as a stereo track.
Then convert to MP3 if you desire.
its that simple....
works great!
Old 12-08-2002, 10:26 AM
Jeff  is offline
That sounds like a very good plan...I know I have cool edit pro somewhere in the archives...
Is there any place where I can get a basic understanding on how to navigate acid?
Old 12-09-2002, 09:24 AM
Polaris20  is offline
Posts: 1,418  -  iTrader: (0)
If you're a one man band, Acid 4 Pro works fine for recording. It supports ASIO, and I can get low latency with it recording guitars.
It also supports VST instruments, which is cool if you pick up an Oxygen 8 or some other USB Midi controller for $150.
As a compositional tool, it is amazing. I love it, and I can't imagine going back.
If I have to record many musicians, I still use Cubase though.
Old 12-09-2002, 05:54 PM
Jeff  is offline
Is there any way I can learn this? The help files/manual/tutorials and whatnot that come with it don't help me one bit.
Old 12-11-2002, 01:59 PM
bob oakman  is offline
Posts: 922  -  iTrader: (0)
The only problem with Acid is that I can never find loops that do what I want them to do and I often dislike the levels between snare, kick and cymbals.. I have been building my drum tracks using all "single shots", beat by beat. Then I can export wav files of each individual drum track, import into Pro Tools, EQ, verb and it sound so much better. Plus, the drums fit better with my wacked out music.
I like it a lot more than using a drum machine, but a lot less than a real drummer, providing said drummer can keep tempo.
Old 12-11-2002, 08:41 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
I've been working with Acid pro 2.0 for a while now, and no problems... it's not perfect, but i can get suprisingly good results from a laptop with it...
-Drew
Old 12-11-2002, 09:03 PM
Jeff  is offline
How does fruity loops compare up to this in terms of features and cool-stuff-you-can-do? I've been using fruity loops for a while and I like it, I just want to know how good acid is once you are literate wtih it.
drum tracks, fruity loops, midi controller
