Recording Studio
Acoustic guitar recording
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
04-12-2006, 12:48 PM
Ant1981
Posts: 2,181 - iTrader: (
How do you guys record
acoustic guitar
I have a washburn which has a battery powered preamp on it with an XLR and jack out. For some reason only the jack out works, but I got my best results with the jack out plugged into a mic preamp on my motu.
Plugged jack into the mic pre gave better results than plugging into a line in and also better results than having the guitar mic'd up with an SM57 plugged into a mic pre.
Ant1981
Find all posts by Ant1981
04-12-2006, 02:34 PM
bduersch
Posts: 1,357 - iTrader: (
Re: Acoustic guitar recording
I, in the classic "go big or go home" tradition, typically record acoustics as follows...
I use a pair of Studio Projects C4 condensers in an "V" pattern, one pointing towards the body of the guitar, one pointing towards the neck. Then I run a 1/4" from the guitar's pickup through a
tube preamp
as well, resulting in 3 guitar tracks.
Similar to the technique I use for recording electric amps/cabs, I like this because it allows me to mix, blend, pan the 3 tracks to achieve the tone I want instead of relying heavily upon EQ. Overkill? Probably!
You probably get best results using the preamp on the motu because the acoustic is most likely sending instrument level than line level... no guarantees, just a hunch. While I'm sure an SM57 technically works for acoustics, I've had the best luck using condenser mics, which are a lot more sensitive for lower-volume acoustic playing. The good news is that even a cheap condenser can make a big difference... I did a lot of acoustic recording with CAD GXL1200's and a Nady SCM900 (both are less than $50) before I got the Studio Projects mics, and generally got some good results.
--B
bduersch
Visit bduersch's homepage!
Find all posts by bduersch
04-12-2006, 02:48 PM
Ant1981
Cool, I'll look out for those condensors then if they are cheap enough.
The acoustic just seemed a bit quiet and distant with the SM57, the gain level couldnt go higher otherwise it would distort, and the guitar (body acoustic hole part) was merely a few inches away from the mic.
Will I get this problem do you think with an SM57 infront of a 4x12? Didn't seem to have any probs even using a 57 or 58 for vocals.
Oh and BTW bduersch, do you know why cubase has three mixers? And do you know any cool rock drum loops I can get hold of?
Thanks
Ant1981
04-15-2006, 02:04 PM
Ant1981
I actually got better results by backing the mic off, 6" inches away, opened the sound up more.
Ant1981
04-16-2006, 11:55 PM
Ibanut
Posts: 223 - iTrader: (
The 57 wont work. Its a dynamic mic and the acoustic guitar isnt a dynamic type instrument. There are too many ways to list but in your situation I'd do like the other guy said. Use the XLR out to a DI box. (look for an active or tube DI) to the pre amp. If you can get a pair of Audio Technica 4033 condenser mics you will get a great acoustic sound. Try recording the acoustic parts in the bathroom if you have a bathroom thats very reverberant. Its great for mixing with 3 acoustic tracks.
Ibanut
Find all posts by Ibanut
04-17-2006, 10:33 AM
Ant1981
Whats the point of a DI box when the output on the acoustic is preamped?
As I said before, only the line out works, not the XLR, for some unknown reason.
I'll look those mics up that you reccomend, on the other hand, what are shure condensors like?
Ant1981
04-17-2006, 02:57 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
i use an older washburn ea-20 for most of my acoustic recording. i typically run the equis 2 preamp into a behringer DI, right into the board. great results. a bit tinny, but sonar tames it. this is strictly for demo work. i sometimes use my lr baggs piezo electrics for DI'ing when i need to be quiet. works great, too. i usually use acoustics blended with electrics, so i don't concentrate on the strength of the acoustic tone as much, its more for attack. but a nice condensor with the piezo will allow for some great blended tones as well.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
04-17-2006, 04:56 PM
Ant1981
So should my XLR not be going straight into my interface then? It didnt sound bad at all when it was jacked into the interface.
Ant1981
04-18-2006, 09:29 PM
Ant1981
I seemed to have exhausted the brains of some of you out there, recording seems to be the most difficult subject so far.
But however, here's another one, seeing as people seem to love two condensers on an acoustic.
Are the Shure PG81's any good for acoustic guitar recording? I've seen some £15 cheaper than anywhere else.
I know people say to use a pair for recording acoustic, are these a good bet?
Ant1981
04-19-2006, 11:45 AM
rty13ibz98
34
most people who mic acoustics will put 2 condensors on it. by the soundhole and then by the fretboard. they will blend the 2. dual source is typically preffered when trying to get the best natural acoustic sound to recordings. since i don't need a super awesome acoustic tone, i usually just DI with a box. i don't like to shoot straight into the board with the line out of my guitar's preamp, i like the security of having my DI "fix" the signal before it hits the board/recording pre's. the bad thing for me personally is that my main acoustic with the best preamp is my ea-20. it is a thinline with cutaway. has really good tone, just not really full. really focused mids, being all mahogany. i would have to mic it with 2 mics and use the piezo to really build up that one's tone. my beater acoustic is a heavily modded fender dg-7. which i have changed all the plastic parts to tusq and brass pins. it has an active
dean markley
barstow piezo in it and sounds really good. that is a great recording guitar. with a condensor picks up the warm lows and spongy mids. with the piezo, is more tinny, but with sweet high mids. really great axe to track with.
bottom line, though. if it sounds good, what is wrong? if you like it, keep on trucking with what you got. experiment, yes, but don't feel bad if your not doing something "by the book". sometimes, depending on our resources, we all have to "make it work".
rich
rty13ibz98
04-19-2006, 12:58 PM
Ant1981
I'll give them a go. The PG81's are condensers, the next one down from the £325 SM81's.
Ant1981
04-21-2006, 11:03 AM
Ant1981
Got two Shure PG81 condensers today, put them on my acoustic, and wow, what a difference condensers make! Sounding good
Ant1981
acoustic guitar
condenser mic
dean markley
tube preamp
what age guitar
how to swirl a guitar
what do the logos mean on ibanez acoustic head
which instrument to record first in a recording studio
what kind of acoustic strings does buckethead use
Sub woofer, Ibanez Acoustic Guitar Golf Clubs
joeydahlia
12:56 AM
My 1st try on pieso acoustic guitar! ;)
dimitar
05:21 PM
Recording the guitar - custom ISO boxes
Jai
Dave Weiner Official Forum Archive (SEE NEW LOCATION)
09:34 PM
Recording guitar solo sound problems - no central presence
sfx70
Recording Studio
04:05 PM
How to transport a guitar to Jemfest for flyers. - Safety fi
Gabe Nickelson
Jemfest Forum
03:37 PM
04:22 PM
