Old 08-01-2004, 10:48 PM
FinnJ  is offline
Posts: 161  -  iTrader: (0)
buying drum mics
hi guys
im looking to buy a set of drum mics for my studio set up, can anyone recommend any good brands?, im looking for a decent set but like everyone i dont want to spend an arm and a leg
cheers
john
Old 08-02-2004, 12:23 AM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
Check out the Nady DMK7 kit:
http://www.nady.com/products/product...umkits_pg.html
It's very modestly priced (under $200), includes 2 condenser mics for the cymbals, a bass drum mic, and 4 other mics for snare/toms. We've been using this to record my band's drummer and had really good luck with it. (We run all 7 mics into a 8-channel mixer, add a little EQ on each channel, consolidate to a stereo mix, then run the stereo mix through an ART tube preamp and Behringer compressor before running into the PC--lots of gear, but certainly not lots of expensive gear!)
The only thing we've changed since we bought the DMK7 kit... we now use an SM57 on the snare to give it a little more "pop". Otherwise, we're using the stock Nady kit.
--B
Old 08-02-2004, 11:28 AM
FinnJ  is offline
cheers bob, do you know of any gear web sites that will ship world wide? the like of musician .com will only ship around that states which is a pain in the arse
Old 08-03-2004, 03:07 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
Hey Finn,
These inexpensive kits are mostly pretty good for the money. The kick mic has to have 2 things: high SPL's and the range must get down around 40-5- Hz to sound good. Some kits have a kick mic that only goes down to 60-80Hz which will not produce good lows.
Stay away from rim-mounted stands- all kinds of niose with those.
I think you get a better sound micing the top heads about 2-3 inches away.
And keep the overhead condensers FAR away from the cymbals for best sound. You'll get room abience that way.
Old 08-03-2004, 04:17 PM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
Agreed: room ambience = good
I love drums that sound really live with lots of natural reverb from the room.
Old 08-03-2004, 05:21 PM
bduersch  is offline
Yeah, for the record...
With the Nady kit, we bought a bunch of boom mic stands, since we learned during our first recording project that mounting mics directly to the drums causes the mics to pick up semi-obnoxious ringing frequencies between the drums. All mics are on stands typically 1-2" from the surface of the drum head, angled slightly towards the center.
Getting a good tone from the bass drum was a big challenge. We cut a hole in the bass drum head and put the mic even with the hole (not through the hole). We then covered the drum &amp; microphone with a blanket to isolate the mic a bit more.
The condenser mics are placed 3-4 feet away from the corners of the drum kit.
All of those mics are then sent into a Carvin mixer, given a little EQ, and mixed down to stereo and compressed before running into the computer.
Lately we've also been running a large diaphragm condenser mic about 10 feet away from the drum kit, just to pick up a little more ambient tone. (We also do the same trick with the guitars... even though each amp is close-mic'd with an SM57, we have a condenser 10 feet away to thicken up the tone a bit.)
--B
Old 08-17-2004, 03:03 PM
FinnJ  is offline
well ive ordered a set of Shure PGDMK6XLR mics
they come with all the mounts and leads, so i should have enough to get going
all of the reviews i found on it are pretty good, so heres hoping!
Old 09-17-2004, 09:54 PM
Images: 13
Excellent! Those Shure kits are superior to the CAD and NADY kits I've reviewed.
Best of Luck! Be SHURE to post some snippetts for us.
Old 10-03-2004, 07:08 PM
FinnJ  is offline
hey guys
heres a track i`ve produced in my studio with the new mics
its a cover of a song by the stunning called brewing up a storm
its a little rough but we are just just using it as a demo track to get gigs
love to know what you think
http://www.iol.ie/~badhorsey/music/brewingupastorm.mp3
you can view the band site at
www.firegardenmusic.com
Old 10-03-2004, 07:25 PM
Drums sound pretty good, I gotta say I'll have to remember those for if I start doing any home drum recording (right now, I can just do it all at the studio at school ).
Old 10-03-2004, 08:33 PM
FinnJ  is offline
thanks two hands, i think there great value
bass drum, condenser mic, tube preamp
