Old 08-11-2002, 03:44 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
Can't Record!!! HELP!!!
Help me guys! I've been doing everything good but can't do it! I'm trying to run my Line 6 Flextone II direct to my computer (PIII 800 with 512 megs of ram and a SBLive! Value card) I run the Send plug in the back to the Line in (there is 2 I tried 1 then the 2nd then a y split to both). I get no sound what-so-ever to record with that. So I looked at all my sound card settings. I have all the settings correct. Nothing is muted, everything works. Any suggestions? pointers? walk-through's? I'm smart with computers but this one is a mellon scratcher!
Old 08-11-2002, 06:59 AM
Carlo  is offline
Posts: 835  -  iTrader: (0)
Did you ever click onto the sound icon? Go there and click on options and then properties. 'Adjust volume for recording'....then hit 'OK.'
I don't know if you did that but it could easily have been overlooked.
Old 08-11-2002, 03:40 PM
yes I did. Like I said I have all my sound card settings correct. Nothing is muted or turned down. The recording parts should all be working. But it isn't...
Old 08-15-2002, 02:32 AM
CQ7String  is offline
Posts: 246  -  iTrader: (0)
Are you running the line out of your amp.. Into the microphone jack on your PC?
If so, perhaps it's an impedance problem?
Plug a set of headphones into the jack that you're running TO the PC, and see if you get sound. If not - that's the problem - try using the headphone jack (if there is one) instead. Otherwise you'll need either some sort of converter, or better yet a "real" soundcard IN for your PC.
M-Audio makes tons of great stuff. Some swear by the Audiophile line, while I use the preouts on my GSP2101 to an M-Audio Delta-44 breakout box.
Give me a little more info on your actual setup and I'll see if I can figure it out.
- CQ7
audio delta
