Old 04-19-2003, 12:12 PM
Jeff  is offline
Posts: 1,501  -  iTrader: (1)
Cool Edit Pro questions
Ok, my first question is this...right now I'm using Cool Edit Pro without a mixer or anything, and I want to record using the line-in on my sound card. Where do I set it so it records from line in?
Question 2...When I try importing a .wav file, it compresses it horribly...any way to not compress it?
Old 04-19-2003, 02:21 PM
Vai the god of Sound  is offline
Posts: 232  -  iTrader: (0)
well, you want to open your volume control beside your clock, then go to options>properties>recording
then select Line-In.
I'm not sure about your 2nd question though
Old 04-19-2003, 02:44 PM
Jeff  is offline
I did as you said, and it didn't work. Am I supposed to uncheck everything BUT line-in or what?
Old 04-19-2003, 05:35 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
What do you mean, "import"? You should be able to just OPEN a wav file, unless the headers are screwed up somehow.
Old 04-19-2003, 07:55 PM
Jeff  is offline
Ok, I think I got it all figured out now thanks to kennydoe. Thanks for your help everyone!
