Old 04-24-2007, 01:00 PM
chopvai  is offline
Posts: 399  -  iTrader: (0)
Cubase SX Users.
Hey there peeps,
Recently upgraded from audition 2.0 to Cubase SX.
I'm running the mixer straight through the pc via USB.
Using Audition, there is no delay whatsover when recording.
when using cubase (steinberg products), whenever I tap the mic, there is about a 1 second delay before it reaches the track?..
So, im guessing since audition workds fine with no time delay, it must be something in cubase? but cannot seem to find the problem.
Please help )
THANKS
Old 04-24-2007, 01:12 PM
EL-CeeDee  is offline
Posts: 484  -  iTrader: (0)
Re: Cubase SX Users.
Are you using the latest drivers ? ( ASIO )
Old 04-24-2007, 11:09 PM
chopvai  is offline
Yeh, Using the latest ASIO Drivers.
Old 04-25-2007, 04:24 AM
StoneLord  is offline
Posts: 113  -  iTrader: (0)
Devices--Device setup--VST Multitrack--control panel.
You set the sond card buffer/latency here.
this is for sx2.xxx dunno if later versions are different.
Old 04-25-2007, 04:34 AM
jimmyfingersminion  is offline
Posts: 219  -  iTrader: (2)
it is the smae on all sx versions. that's it, change your buffer settings.
Old 04-30-2007, 05:04 PM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
Just another reason to have a click track. for a few measures before the music starts, tap your pickup or hit muffed strings along with the click, or even the drum track, then visually review the waves and see if the spikes line up, if not, just drag them till they do. Even after goofing with your buffer, you may find it near impossible to get them to line up perfectly, and also, since PC's are finicky and sometimes run something in the background when you least suspect it, this can also change the latency temporarily. It's no big deal the drag the track back a little bit to line it up. Turn off the "snap to" setting so it doesn't 'snap' to the nearest 1/4 note, increase the viewable area. It's really only a few clicks even though it may seem like more aggravation reading this.
Let us know how it works out, and post a clip when you get something. I'll be happy to host it for you if you do not have anywhere to upload it.
Later, Darin
Troubles with Zoom pedal and Cubase. Sam b Gear and Equipment 7 01-09-2007 05:41 AM
Any Cubase users? Ant1981 Recording Studio 16 04-17-2006 04:57 PM
Audio out of sync in Cubase VST Azrael Multimedia: Music, Pictures & Sounds 3 12-04-2004 04:04 PM
BR8 to Cubase - Having trouble recording BR8 to Cubase MikeyJ Gear and Equipment 4 02-28-2002 08:01 PM
Roland users...Come in Roland users! Vaibanez Gear and Equipment 0 08-27-2001 10:02 PM
