Recording Studio
electric shock while recording
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
07-05-2007, 01:02 PM
Shredtillubleed2death
Posts: 18 - iTrader: (
i get electric shock in my strings when i try to record in my computer..
What could be the problem.. and its grounded properly.. plz help
could it be the problem of ATX box or power supply??
Find all posts by Shredtillubleed2death
07-05-2007, 11:26 PM
yoyo1299
Posts: 637 - iTrader: (
Re: electric shock while recording
ahhhh no. ur producing static electricity somwhere. are u playing on a carpet floor? if so, there's your problem. ur building up static electricuty, and when u touch the strings, u release the charge and close the circuit. bam! ur shocked
yoyo1299
Find all posts by yoyo1299
07-05-2007, 11:31 PM
MF_Kitten
Posts: 219 - iTrader: (
actually, if you touch the strings of our guitar and then touch a microphone with your lips, like barely touching it, you get a little ´´licking a 9v battery´´ feeling on your lips... same goes for having your lips/face on the mic and barely touching the strings...
dunno why it happens, though...
MF_Kitten
Find all posts by MF_Kitten
07-09-2007, 01:02 AM
elcid
Posts: 8,720 - iTrader: (
Are you positive everything is grounded correctly?
elcid
Find all posts by elcid
07-09-2007, 05:42 AM
Devo
Posts: 1,483 - iTrader: (
yoyo1299
no offence but dont believe this nonsense...
There are several sources of shock which can be deadly... which gladly this one wasnt!!!
Its hard to figure out what is the cause exaclty but since it only happends when your recoding into your computer it must be a faulty earth in the computer somewhere... and unless your a computer whiz its going to be hard to find out where.. or fix it.. but first thing to try would obviously be replace the soundcard ... then next step would be the motherboard...
However, as an alternative... if you follow this link there is a simple mod you can do to your guitar (add 1 capacitor to the bridge ground) to prevent 'some' electric shock caused by dodgy equipment grounds...
http://www.guitarnuts.com/technical/...fety/index.php
Unfortunatly us musicians usually use ourselves as electrical testing equipment...
Good luck
Steve
Devo
Find all posts by Devo
07-09-2007, 06:15 AM
Mike239
Posts: 402 - iTrader: (
Reviews: 6
Since i have an indoor TV antenna in my room, I've noticed that if i accidentally touch the antenna while i'm playing i get a nasty little shock a fair bit worse than licking a 9V, and using just that energy produced the guitar and amp, if i place an LED between me and the antenna it will light up, Its amazing how much electrical energy surrounds you when you play the guitar. So i would suggest the same as others, Check your grounding the energy is leaking from somewhere then onto your trem and onto the strings and when you play your completing the circuit.
Mike239
Find all posts by Mike239
07-09-2007, 08:08 AM
Distantshore
Posts: 3,671 - iTrader: (
Mike239
An LED?? Wow thats crazy, I never would have thought!
Distantshore
Find all posts by Distantshore
07-09-2007, 08:43 PM
Mike239
Reviews: 6
Distantshore
Oh the LED was just to test how much voltage and current i had running through me when i play, it's a surprising amount about 2-3v.
Mike239
07-09-2007, 10:44 PM
yoyo1299
Devo
Good luck
Steve
maybe this isn't the cause, but it's not nonsense. i've done it to myself (in other cases) a lot. just wearing a thick sweater then touching metal can give a shock.
yoyo1299
07-09-2007, 10:50 PM
newbieguitarmaker
Posts: 4,030 - iTrader: (
rofl I'm always full of static except when I play guitar. I could probably put a led in my mouth and light it up at like publix but when I'm
playing guitar
I get nothing. Is your pc on a carpeted ground? or is it up on a desk?
newbieguitarmaker
Find all posts by newbieguitarmaker
07-10-2007, 03:55 AM
Dino
Posts: 1,721 - iTrader: (
Dude, just go wireless and forget about it.
Dino
Find all posts by Dino
07-12-2007, 02:58 PM
tobe
Posts: 260 - iTrader: (
You have a ground issue. Static electricity can shock you of course, but you need to generate it, and simply standing still and playing your guitar W/O moving around AT ALL, will not do it.
Depending on how old your house is, the wiring could not be properly grounded. Are you plugging your guitar directly into the computer's sound card or into something else first?
If you are using two different circuits, one on the computer, one for the fx box whatever for the guitar, the polarity could be off. Try using a ground lift plug to remove either the guitar or the the computer from the loop. Just be careful though, as MF_Kitten pointed out
"... actually, if you touch the strings of our guitar and then touch a microphone with your lips, like barely touching it, you get a little ´´licking a 9v battery´´ feeling on your lips... same goes for having your lips/face on the mic and barely touching the strings..."
a ground issue at the very least can hurt, at the most it can KILL.
If you are not comfortable with trying to fix the issue, talk to an electrician. Good luck!
tobe
Visit tobe's homepage!
Find all posts by tobe
playing guitar
are jay turser electric guitar worth buying
which i do use strings for electric gitar
which instrument to record first in a recording studio
which electric guitars use stainless steel frets
how do you play Here We Go Again on the electric guitar
recording recomendations Dave?
nouromenon
Dave Weiner Official Forum Archive (SEE NEW LOCATION)
12:49 PM
Pictures of everyone's recording studio or recording gear
rikkbeatty
Recording Studio
38
08-22-2005
04:17 AM
Electric shock from a guitar
barney
Tech: Setup, Repairs and Mods
02:16 AM
Need new recording setup
Beavis
Recording Studio
08:47 AM
Recording Electric Guitar: Mic or direct out? - Which way is
davester1234
Gear and Equipment
04:47 PM
11:17 PM
