Recording Studio
Guitar Rig 3
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
11-21-2008, 04:54 PM
TequilaKing
Posts: 293 - iTrader: (
Guitar Rig 3
Im considering buying Native Instruments Guitar Rig 3... anyone here used it? If so whats ur opinions - good or bad
Cheers
Karl
TequilaKing
Find all posts by TequilaKing
11-21-2008, 05:31 PM
taracatac
Posts: 873 - iTrader: (
Re: Guitar Rig 3
I have it and use it a lot. I don't play gigs anymore, so the half-stack was overkill for my house. If you don't buy the foot pedal, you need a pretty decent audio card, otherwise latency is an issue. It is very versatile and I am able to get the tones I want. If you need something for playing live, then I would go for a "real" amp.
taracatac
Find all posts by taracatac
11-22-2008, 07:10 AM
TequilaKing
Re: Guitar Rig 3
hey, thanks for the reply
could you recommend a good audio card?
I've just this minute found the trial version on the NI site and downloaded and installed GR3 and yep, i've experienced notable latency on my stock Dell pc's soundcard
TequilaKing
11-22-2008, 10:53 AM
_FR0D0
Posts: 528 - iTrader: (
Re: Guitar Rig 3
TequilaKing
it depends on how much do you want to spend, and if you want mobility. PCI/PCIe/PC Card/Card Bus/Firewire are ok latency wise, stay away from USB ones.
_FR0D0
Find all posts by _FR0D0
11-22-2008, 11:23 AM
taracatac
Re: Guitar Rig 3
Before I bought the foot pedal, I used a an EMU 0404 internal PCI sound card. About $100 new. You can get them on the Bay for 60-70.
taracatac
11-22-2008, 02:29 PM
fyrie
Posts: 397 - iTrader: (
Re: Guitar Rig 3
I just ordered GR3 Kontrol edition online. I hope the latency is ok. I'm skeptical since it's USB, but I've read plenty of people say the latency is ok with the kontrol pedal and a fast computer.
fyrie
Visit fyrie's homepage!
Find all posts by fyrie
12-03-2008, 03:39 PM
fyrie
Re: Guitar Rig 3
My Guitar Rig 3 Kontrol Edition showed up the other day. I plugged it in the first night and I was pretty let down. I couldn't get acceptable latency without a lot of clips and pops. I put it back into the box to return it. Fortunately I did a little research and found some tweaks for XP. I performed the tweaks, and plugged it into a different port with a different cable. I was able to get it down to the lowest latency settings without any audio artifacts. I must say that I am now very impressed with the latency over USB. I am very happy with GR3 and I recommend it to anyone who has a beefy enough computer to run it.
fyrie
12-03-2008, 04:04 PM
AxeHappy
Posts: 678 - iTrader: (
Re: Guitar Rig 3
I've had no latency problem using it as a plug in Pro Tools and my computer is plently crappy. Maybe I'm just lucky Haha.
AxeHappy
Find all posts by AxeHappy
12-03-2008, 04:08 PM
S-man
Posts: 1,757 - iTrader: (
Re: Guitar Rig 3
Not really familiar with it. But would like to say ......make sure you are using ASIO drivers.
Don't know if there are any other options but ASIO with it anyway?
S-man
Find all posts by S-man
12-03-2008, 04:29 PM
fyrie
Re: Guitar Rig 3
For those wondering, here are the tweaks I did:
- Disabled
unused
onboard devices (Onboard HD Audio, Firewire, Raid Controller)
- Turned off power management on the USB ports
- Set CPU priority to background services
It made all the difference in the world. I can use a 1ms usb buffer/2ms audio buffer @ 96000 Hz. According to what the driver panel says that is 9ms in to out latency. That feels about the same as a saggy tube amp to me. I wish it were a little less, but I'll take it. It appears that is the least amount of latency the ASIO driver will allow for.
My PC Stats:
XP 32 SP3
Intel Core Duo 2 @ 3Ghz
4 GB Ram
Asus P5K motherboard
10,000 rpm SATA hard drive
fyrie
12-03-2008, 05:44 PM
Jaden
Posts: 2,464 - iTrader: (
Re: Guitar Rig 3
Karl,
looks good, sounds bad..
ive used it and then used a proper amp back to back and while guitar rig was great while I was playing it after I plugged into a proper amp the transition was such a contrast.
it was like I had to try and force the playing when using GR3 and there was no character or decent harmonic undertones that you take for granted when using a decent amp.
godd enough for pissing about on the PC with though.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
12-04-2008, 03:55 PM
AxeHappy
Re: Guitar Rig 3
Yeah, it really doesn't stack up next to a good Tube amp. I think it is the best amp modeller you can get. Maybe Eleven by Digidesign but that cost $500 or something ridiculous like that.
AxeHappy
12-10-2008, 07:19 PM
fyrie
Re: Guitar Rig 3
AxeHappy
I completely agree. To my ears it sounds better than the Line 6 amps and even better than my old Johnson modeling amp that had a tube preamp. It's not amazing, but it's good enough to the point where I don't feel like it sucks my inspiration away like some modelers do.
A tip: I haven't tried this myself, but I've read about people taking their tube amp, and running the recording line out of the amp, or even better yet, the recording line out of a hotplate into guitar rig using ONLY post fx and a cab emulator.
fyrie
12-27-2008, 03:36 AM
buluketek
Posts: 21 - iTrader: (
Re: Guitar Rig 3
i got the guitar rig kontroller a few months back and it sucks, to say the least. its nothing compared to my DSL 100. couldn't get a decent marshall tone even when using the plexi/lead800 in there.
i have a question.. now that the kontroller already has a built in sound card, is it possible to hook up a mic in there and record from my tube amp instead?
buluketek
Find all posts by buluketek
what guitar ibanez guitar is shawn lane using in his video
how do i fix a synsonics guitar?
what age guitar
what to use to lubricate nut on guitar
how to swirl a guitar
Guitar Contest @ Guitar Center - *Crystal Planet Encounter
Rodney James
10:41 PM
Guitar Player, Guitar World Back Issues (Satch & Vai)
jippy
01:40 AM
Where is this guitar made? http://www.ibanez.com/guitars/guitar.asp?model=RG3120F
DotNetTim
01:07 PM
FS: Guitar Player/Guitar World Back Issues
jippy
10:02 PM
08:39 PM
