Old 07-12-2009, 08:43 AM
Paw  is offline
Posts: 106  -  iTrader: (1)
Images: 4
Lightbulb
Help me bring the volume up!
My problem: I have a hard time bringing the tracks i record up to a decent volume when compared to the volumes of an ordinary CD-track. I don't want to go as loud as Death Magnetic or Californication, but I'd like to not hear a significant drop in volume when going from a random track to my track. I really don't know why my tracks turn out this silent, because the volume on the master fader is mostly high (often almost clipping). I use compressor on some of the tracks to bring up the volume and keep it consistent. I use ProTools LE 7.3 for reference.
Do you guys have some kind of method to mixing and bringing up the volume? I want to learn as much as possible as I'm quite new to recording and mixing.
Thanks!
Old 07-12-2009, 08:48 AM
UV-7-BK  is offline
Posts: 1,403  -  iTrader: (3)
Images: 33
Reviews: 21
Re: Help me bring the volume up!
whats your input volume like?? what gear you using,people here mght be able to offer suggestions!!!
Old 07-12-2009, 09:50 AM
Paw  is offline
Images: 4
I use a MBox2, Sm57 and Sennheiser 906 as well as DI with my keyboard. I'm not 100% sure what you mean with input volume (how much volume the mics record?). I always adjust the gain to get most volume possible without any clipping. Hope that clears anything up. The problem is probably that I don't know how to mix and bring up the volume properly, but I'm open to all suggestions. Thanks!
Old 07-12-2009, 12:12 PM
rty13ibz98  is offline
you need a brick wall limiter like the waves L2. it is a severe compressor that keeps your level as hot as possible without clipping. get a good mix then use the limiter to get it hot. don't mix too much into the limiter or your mix will lose life and be nothing but loud.
rich
Old 07-12-2009, 12:13 PM
i explained a lot in this thread:
http://www.jemsite.com/forums/f34/whats-next-91871.html
Old 07-13-2009, 08:39 PM
Paw  is offline
Images: 4
I found out I had a plug-in called Maxim. I read a bit about it and when I found out how it worked I got the results I was looking for. You guided me there so I have to thank you guys! Thank you very much!
mix mixing volume db
Patriots haters....bring it on!! uberthrall Off-topic / Miscellaneous 111 02-04-2008 07:16 PM
bring back the 540P-II rjd_72 Other Ibanez Guitars (including Premiums) 32 08-27-2006 05:02 AM
someone help me bring this auction down rich2k4 JEM and Universe Guitars 21 03-31-2006 04:21 PM
Where to bring my Guitar in NJ dragsternj Other Ibanez Guitars (including Premiums) 3 05-13-2005 10:48 AM
should i bring my guitar in for repairs? Ash Tech: Setup, Repairs and Mods 8 10-09-2002 05:16 AM
