Actually, 50% RH and 70 degrees F is fine. 45% RH is probably "ultimate", but you're pretty close. That's a pretty dry basement - mine gets to 70% in the summer without dehumidification.
The main thing is, if you're comfortable, your guitars should be too. So 60-80 degrees F, and 40-60% RH should be fine.
