Re: Line6 Toneport & Cubase Studio 4? HELP
I think that your P.M.T staff member may be slightly wrong. You WILL NOT be able to do anything with regards M.I.D.I and the set up that you describe. However, it is very easy to rig your toneport to your computer to record in cubase.
1) Install Gear-Box.
2) Plug in the tone port.
Once this is done you have to rig up a separate audio-out to a hifi, or whatever speaker you choose to use.
3) Configure Cubase to recognise your using the toneport as an audio input AS WELL AS audio output!
There you go it should be that simple!
Take care,
Chris
