Originally Posted by GuitarEvan07
Hey guys, I have a Kodak Easyshare digital camera that has a video option(you can do videos as well). I am getting a Boss Br-600 digital recorder for Christmas to record me playing guitar(audio) and I want to use the camera to get video. Is there an easier way to match up audio and video rather than going in windows movie maker and manually aligning it? Thanks!
For the gear you mention, Yes a Slate is the way to go.
What you'd be using is called a "dumb slate" or "clap board"
Most productions (myself included) use "smart slates" or "timecode slates"
these days. On your recorder you have timecode being recorded. You have to properly set up the correct frame rate, sample rate for the correct Film speed, and also figure out what process will be used to "sync" the material,
This process is called telecine.
With a smart slate its very quick and easy to sync.
Every few hours you connect the Smart slate to the recorder via a special connector and "jam" the slate so it has the same
timecode showing on it that the recorder has in its display. Disconnect the cable, and the smart slate continues with those numbers
with its internal timecode generator.
On the picture when the timecode numbers are moving on the slate..
just pause the picture at any point. Say the number on the slate is
08.52.13.16
You just goto the audio file, and find the same moment in time...and line them up. In todays edit systems..its as easy as pausing the picture...
and with the audio already in your bin..just type the timecode number
into an import box..and the program goes and finds which audio file has
that timecode number, it imports it, and places it at the right place.
But anyway, back to your question.
The biggest issue you're going to have is drift on longer takes where
the audio/video will be in sync at the start..but a few mins in..
the picture/video start to drift apart. It all depends on the stability of
the clock in your recorders.
If you can, put a slate at the END of the take as well.
Sync the beginning.. and then play the ending..see if its drifting one way or the other.
If it is.. just watch the clip notice where it starts to visibly drift..
break the audio file apart..and slip the audio back in sync at that point.
Continue watching it again if it happens and repeat the process throughout.
Its not as bad as it sounds.
