Recording Studio
Mics for studio use
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
01-01-2006, 10:15 PM
Ant1981
Posts: 2,181 - iTrader: (
Mics for studio use
Hi, I'm after some adivce about mics. What I want to do is record some practice of my band by putting two mics in the room, one left and one right. What mic or type of mic would do this?
I was looking at the Shure SM57, which is good for micing up amps, but i'm not sure if it will pick up the whole room.
Ant1981
Find all posts by Ant1981
01-01-2006, 10:24 PM
Ferrous Lepidoptera
Posts: 472 - iTrader: (
Re: Mics for studio use
Caveat: I'm not any sort of expert, strictly amateur.
I would say an SM57 wouldn't be a very good choice for that sort of mic'ing. They are somewhat directional, (cardiod, iirc) for starters. Many people use Oktava MC012's (or similar Marshall 603s) as drum overheads, perhaps they'd work as room mics for a similar price as the SM57, and being condenser mics would likely be more sensitive, and pick up the high end a bit better. (Both need 48V phantom power, iirc.)
Another cheap option might be radio shack or Crown PZM mics, typically $100 apiece or so, and good at recording some tough to record things, (e.g. piano.)
Eh, them's my thoughts. Take with a lot of salt, because I might be talking out my (oh yeah, this site censors, doesn't it.)
Ferrous Lepidoptera
Find all posts by Ferrous Lepidoptera
01-01-2006, 10:57 PM
JESTER700
Posts: 2,234 - iTrader: (
Amateur or not, that's good advice. Stereo array (X-Y or ORTF; google those terms) with cardioid (directional) small diaphragm condensors is probably the best bet. And later if you get into fancier recording, you can use them as overheads. I'm not familiar with the cheaper chinese small mics (though I've had Shure Sm81s and Audio Technica AT4053s), but my Marshall large diaphragm is good, so I'd guess the 603 would be decent. I'm sure there are many choices...
JESTER700
Find all posts by JESTER700
01-02-2006, 06:24 PM
Ant1981
Ah yea the condensors, I've seen some on the cieling of rehursal studios before, the ones that are almost triangle in shape, taper at the top of the mic, are those the sort you're refering to?
Ant1981
01-03-2006, 03:23 PM
Ferrous Lepidoptera
They look like:
Marshall MXL 603s
oktava mc012
. (links go to google image search). They look like a metal cylinder about 6 inches long, and a little less than an inch in diameter.
The PZM's (Pressure Zone Mics) are a bit weird looking, like a flat, square metal plate.
Crown PZM
Radioshack used to resell the Crown PZMs, I think, or got Crown to make them some mics or something. They look almost the same, but with radioshack branding.
03:31 PM
Ferrous Lepidoptera
01-03-2006, 07:39 PM
bonehead189
Posts: 537 - iTrader: (
If a condenser or SM57 mic dosen't work, just add a little room or hall reverb to the mic or whatever is being miked. That should help out a 'bit for the feeling of the whole room.
bonehead189
Visit bonehead189's homepage!
Find all posts by bonehead189
01-03-2006, 09:10 PM
Ant1981
hopefully a condenser will work, that should do so that i can record band practices
Ant1981
01-04-2006, 04:28 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
i actually use an akg c2000 and c3000 for my condensors. i don't like live singular sourced mic'ing. for my band we use a behringer mx3282a board to bus everyone down to 8 tracks into an m-
audio delta
1010lt card into sonar 4. that way, we are all on seperate tracks going in. it helps that i use an electronic drumset and all of us DI into the board. we only use condensors to track vocals with after the fact. for live vocals we use sennheiser e835 mics. i have some sm-57 and 58s laying around if i need them, but the e835's kill them.
for you tho, i would totally recommend a similar setup...on a budget. decent digital 4 tracks are really affordable now(i recommend 8 tracks), as are small mixers. if you end up sub mixing the drums with a small 6-8 channel mixer to stereo you will free up alot of track space. if you are really strapped for inputs, pan all the drums to one side and the instruments and/or background vocals to the other side. then keep your lead vocals fed straight into the recorder. typically your going to want to keep your drums so you can cut a demo to them and not have as much bleed over from the other instruments...bleed over is an inerent evil in live mic'ing, but this will suppress it some. the other panned track becomes scratch tracks for cueing purposes. vocals fed DI into the recorder are more flexible than the ones grouped with instruments.
the mic's that i would recommend are the akg's and i have used those cheap mxl 990's. those are incredibly good mics for the money. really warm midrange, but are way cheap. you could get 2 for less than $150. just remember your phantom power.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
01-04-2006, 07:17 PM
JESTER700
rty has a point, but that's a LOT more gear to buy. May or may not be worth it, depending on needs. And other bills...
JESTER700
01-04-2006, 10:03 PM
Ant1981
Money isn't an issue, I've even looked at the Boss BR-1600CD that can record 8 tracks at once, but I need something practicle just for recording the practises, so a few condensers was an idea, as micing everything up would take time, and i'm guessing i'll lose some tone and feel if i di amps into the recorder.
Those akg's, are they good for recording the live stuff in a rehursal room?
For a demo cd, we would mic everything up, but at a more practically allocated time slot, rehursals are 2 or 3 hours, not enough time to set up mic's for everyone and get the levels set.
Ant1981
01-04-2006, 11:43 PM
JESTER700
The C3000 & C2000 are large diaphragm mics - not generally used for stero miking, but possible. The C1000 is more along the traditional lines, but I'm no fan of it, though I like many AKG mics (I liked C460s for stereo pickup and my main vocal mic is a C414BULS). For practices, a stereo array (or even a mono mic) will give you an idea of your live sound in that room, but not much more. I'd try it & see if it gives you what you need. If not, you can expand the rig for multitrack work with nothing lost.
JESTER700
01-06-2006, 03:14 PM
Gresh
Posts: 1,416 - iTrader: (
Rode offers a lower cost set of matched pencil condensors meant for stereo mic'ing applications...sort of along the same lines as the NT1A large dia. condensor as far as pricing goes. THe NT1A is a great bang for the buck mic, so if the smaller dia. condensors are of the same caliber then they might be something to check out for your application. Above replies are right though, typically larger dia. condensors are seldom used for stereo mic'ing, but the cool thing is that there are no rules so whatever works!!!
Gresh
Find all posts by Gresh
01-09-2006, 12:25 PM
Drew
Posts: 4,538 - iTrader: (
FWIW, two C1000s's sound absolutely heavenly in an X array on an acoustic... I've never tried mine as stereo room mics, but they're fairly balanced sounding, so if your room's any good, they might work.
Drew
Visit Drew's homepage!
Find all posts by Drew
01-09-2006, 05:38 PM
desertdweller
Posts: 48 - iTrader: (
Drew
Some engineer snobs will disagree with me, but I love the C1000s mics for vocals and drum overheads as well. That's what we're using on our album. I love the sound they produce, it's very close to what my ears hear, if not a little warmer.
desertdweller
Visit desertdweller's homepage!
Find all posts by desertdweller
01-30-2006, 10:09 PM
Ant1981
I'm thinking soon of getting the
multi track
and recorder, not sure what mics to get in first
Ant1981
audio delta
condenser mic
multi track
rack space
why are my mics muffled
how to put furniture in a studio
What year is my Boogie studio 22
which tubes for my studio-pre
which instrument to record first in a recording studio
More demo clips (MP3's) of different mics (SM57, e609, i5, GI100)
bduersch
Recording Studio
01:05 AM
Mics under $300 for metal guitar
guitarkatana
Recording Studio
01:35 PM
Delay units for mics
Al M
Gear and Equipment
12:13 AM
Rhodes NT1 Nt3 mics
FinnJ
Recording Studio
01:12 AM
Anyone use old Ribbon mics?
jay ratkowski
Gear and Equipment
12:09 AM
04:20 AM
