Recording Studio
Midi delay problem
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
07-05-2005, 01:47 AM
JN777
Posts: 184 - iTrader: (
Midi latency problem
hi, i just bought an Oxigen 8
midi controller
"usb". and im having trouble using it, cuz the signal is delayed, the sound comes after a little while i touch the key. Im using
Fruity Loops
Software.
On a laptop
e-machines
amd sempron 1.6ghz
Ram 512mb
Windows XP
Could you recommend some hardware or something that is missing?
thanks for your help folks
02:27 AM
JN777
Find all posts by JN777
07-06-2005, 12:19 PM
rgr
Posts: 1,791 - iTrader: (
Re: Midi delay problem
From what you have listed, I'm guessing that you're probably using the built in sound card for your MIDI sounds. I have the same problem with mine, I think it is that the built in cards are kinda generic and the manufacturers don't care about the timing, they aren't designed to be "professional quality" (at least that's my guess). When I use the MIDI port on my Edirol 2496 to trigger sounds from my Juno-D, the delay is unnoticeable, if I use the built in card, the delay makes it unuseable.
This has been my experience, others may be able to help you more.
Roger
rgr
Find all posts by rgr
07-06-2005, 01:21 PM
Polaris20
Posts: 1,418 - iTrader: (
You need to get a CardBus card, such as the Echo Indigo or at the very least, an Audigy CardBus card, either of which supports ASIO, which is what you need for low latency in FruitLoops.
What you're hearing is the result of the stock soundcard driver's inability to process the sound fast enough.
There is ASIO4All, which basically is an open source driver for many stock sound cards, but I couldn't get it to work with my laptop, unfortunately.
It's a shame to spend $125 to $200 on a laptop card when all you're doing is playing back sounds, not recording. But that's what it has to be, unless you get ASIO4All to work.
http://www.asio4all.com/
Polaris20
Find all posts by Polaris20
07-06-2005, 01:53 PM
jimmyfingersminion
Posts: 219 - iTrader: (
if you are trying to use the on board sound set of a dodgy sound card. or, even worse, the wavetable synth ( worst. idea. ever). you will have terrible latency. invest in a slightly better card. even something like a soundblaster audigy card will give you much better results. hope that helps.
jimmyfingersminion
Find all posts by jimmyfingersminion
07-06-2005, 04:32 PM
unique77
Posts: 124 - iTrader: (
Try a different sound card, one you can get with a usb built right in. Alot of the time its the usb slowing it down, make sure your using a high speed usb port and that its not sharing with any thing else you might be using. With usb, one port can be slowed down because the speed of it is often shared with all the others. The nice thing about having something with firewire is that the speed output is consistent unlike usb. Try a high speed usb card (not a hub) or a sound card with usb built in wouold be your best bet.
Ryan
unique77
Find all posts by unique77
07-06-2005, 04:52 PM
Polaris20
jimmyfingersminion
With all due respect, did you even read the response I gave? It offered a solution to use the onboard sound with a low latency driver, without spending any money. This will work fine provided he's only using it for playback.
unique77
USB has nothing to do with this, and adding a USB sound card, while it may reduce latency due to the fact that most have ASIO support, is not the best solution.
USB audio interfaces tend to have higher latency (even with ASIO support) than firewire or CardBus solutions.
If the original poster is going to record, then the best solution would be either a Firewire 410 from M-Audio, or a Echo Indigo I/O, with something like a Presonus BlueTube DP.
If he is just going to playback software synths and samplers from FL, then either the ASIO4All or Creative Audigy CardBus will work, for far less.
Polaris20
07-06-2005, 05:06 PM
unique77
Woops, i totally read this wrong. I was thinking about something totally different. I would go with what polaris said, which is right on.
unique77
07-09-2005, 02:03 PM
JN777
thanks to everybody for your quick replies. i just installed the reason program that comes with the oxygen 8 keyboard, with that software the sound has a little less latency but still unplayable im just able to play slow chords, i use it together with fruity loops and latency improves, but like i said still unplayable.
Is the Audigy the cheapest solution? how much does it cost? and the other sound cards????
Thanks to everybody
Sorry for my english.
JN777
audio interface
fruity loops
midi controller
how much delay to use for solos
recording guitar through midi card?
how to use midi in boss gt5
how petrucci connect midi in triaxis
midi how to use boss gt 5
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault
leonard deroma
06-18-2007
11:57 AM
midi pedal delay
sindlei
Gear and Equipment
12:16 PM
Cool new toy--Casio MG510 MIDI guitar!
bduersch
02:16 PM
MIDI me this, MIDI me that - The "joys" of MIDI
adamquek
Gear and Equipment
01:50 PM
MIDI Dilemma - soo many cables so few jacks
ellsobrien
Gear and Equipment
05:13 PM
03:35 AM
