Old 10-04-2002, 01:55 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
Muffled Shure SM57 guitar mic
here's the thing. My friend got a SM57 for his guitar cab. This old ****ty 20 dollar mic sounded good. This thing makes his guitar cab sound like a blanket is put over it. When we finally get it to sound good on tape it sounds like total **** live. My other friend says it's because we are running it from an XLR to a 1/4 inch adaptor plug. Any suggestions?
Old 10-05-2002, 04:20 PM
Lonely Raven  is offline
Posts: 491  -  iTrader: (2)
I'd have to agree that the conversion to 1/4 is killing it. The Sure Mikes
need lots of voltage and a good PreAmp to sound good. I had one sitting
in a drawr for years because I thought it sucked. As soon as I got a good
Pre for it, that SM-57 quickly became my favorite!!
Old 10-06-2002, 08:40 PM
30yroldpig  is offline
Posts: 374  -  iTrader: (0)
Going from XLR to 1/4 Inch is not killing your sound. It all depends if it's a mono or stereo 1/4 Inch and how it's wired inside. There are multiple factors why your sound is crap:
-The wires in the cable (or the adaptor) are reversed, causing a poliarity inversion on the signal
-Pre-amp could be problematic
-A 20$ dollar mic hmmmm
There are also room acoustic issues and micing techniques that come into play here.
Good luck
Old 10-07-2002, 12:34 AM
Pat7. We've tried several cables. We've tried mono cables, and stereo cables. We played with mic levels and distanecs for a full 8 hours with no results. Moving the mic away from the cab results in more muffled tone. There is NO preamp. It's going straight from mic to a digital 16 track. And my friend said they were 7.99 on sale from ***************.com. They are Nady Starpower 1 mics. Sound abosolutly perfect.
Old 10-07-2002, 02:03 AM
What kind of digital 16 track? What brand?
How can you play with levels without a pre?
And my friend said they were 7.99 on sale from *******.com. They are Nady Starpower 1 mics. Sound abosolutly perfect.
I thought you were talking about shure mics? How can they sound perfect if the sound is muzzled when you move it?
I justy don't understand...explain
Old 10-07-2002, 05:59 AM
ok the 16 track is a Fostex. We've played with the EQ on the recorder...it still sounds muffled. And the ones we've been using before this Shure SM-57 were 7.99 Nady Starpower 1 mics. Those sound perfect. This Shure SM-57 is a joke.
Old 10-07-2002, 01:25 PM
Anonymous  is offline
Posts: 347  -  iTrader: (0)
If that's the one that you paid 20.00 for then you've been ripped. Looks like the cap is finished.
Old 10-07-2002, 04:13 PM
no no no we didn't pay 20 dollars for anything. 799 for the Nady Powerstar 1 mics. And 79.99 for the Shure SM-57
Old 10-10-2002, 12:59 AM
ardell henderson  is offline
Posts: 146  -  iTrader: (0)
ryan, what kind of sound are you trying to mike?
Bright?
Beefy?
Clean?
Recto-fried?
what head?
what cab?
my sm-57 works great - it rolls off the high end a tad, just like it's spec'd - no problems...
Old 10-10-2002, 01:01 AM
one more thing, when you say it "sounds like crap" - what exactly does that mean?
Old 10-10-2002, 03:05 AM
we got it to work now going from XLR to XLR. But we had to have it ear screeching bright for it to sound at all like a normal guitar....if we had a normal guitar sound....it would sound like someone put a blanket over the cab and put the mic like 30 feet away. We got it now. Thanks for your help....although 90% of the time everyone was confused..probably my fault. Thanks everyone.
Old 08-17-2006, 03:34 PM
TommyGuitar  is offline
Posts: 206  -  iTrader: (0)
Re: Muffled Shure SM57 guitar mic
Your friend was right. It's an impedance problem. You can't go straight XLR to 1/4", you need an impedance transformer or it will sound quiet and muffled.
Old 08-17-2006, 03:41 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Holy old thread bump, Batman!
I'd be curious to see what RSVampire has to say, if he's still around. I had a similar experience where I preferred a cheapo $30 radio shack mic to a SM57 for the longest time, but I just picked up a 57 recently and I've been blown away by just now natural it sounds on my amp now. I suspect that they're a LOT more sensitive to mic placement than the cheap vocal-oriented mic i was using back then, and the fact that it always sounded harsh and buzzy to me (admittedly, the opposite of RS's problem) was just because I didn't know how to mic a cab and EQ an amp to record. Well, to do it WELL, anyhow.
Aside from that, if you can't get a serviceable tone out of a SM57 on a guitar cab and it's NOT user error, there's got to be something wrong with the mic or signal chain. It's such a classic combination for a reason; it shouldn't require heavy EQ to make it sound "passable."
Old 08-17-2006, 04:02 PM
oh yeah I'm still around bro. I've acually fooled around with recording a lot more since then. I've found out that my recordings sounded like crap because the Fostex recorder we used was total crap. The mic pre's in that thing makes everything sound like a donkey kong turd. I bought a really nice tube mic pre and it sounds MUCH better (that took awhile to figure out as well because I had to figure out that the mixer board mic pre level had to be set to 0 for it to sound good). So basiclly all my problems came from my equipment having the quality of a hard boiled egg.
