Recording Studio
Norwegians, need help on power converting..
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
02-01-2006, 06:16 PM
Eddie88
Posts: 150 - iTrader: (
Hi, I'm ordering a POD Xt Live from America (I live in Norway).
Is it enough to just buy an adapter for the Xt here in Norway? Or do I need anything else?
Help is greatly appreciated!
Eddie88
Find all posts by Eddie88
02-01-2006, 08:29 PM
pawel
Posts: 2,656 - iTrader: (
Re: Norwegians, need help on power converting..
I don't know if the unit itself is any different, I have a US Yamaha preamp and I just use a transformer...
pawel
Find all posts by pawel
02-02-2006, 08:32 PM
straymond
Posts: 717 - iTrader: (
I believe it would be enough to buy a converter to the amercan adapter
straymond
Visit straymond's homepage!
Find all posts by straymond
02-07-2006, 02:08 PM
Eddie88
So it's not enough with an 220V adapter for it?
Eddie88
02-07-2006, 02:24 PM
pawel
It depends whether the construction of a US unit and an european unit differs in any way. If it does, you'll probably need a step-down transformer, if it doesn't, a european power supply should do. If the unit can operate in both 110 and 220 modes, then you will only need the little adapter for the actual plug.
pawel
03-01-2006, 03:57 PM
BlueGrot
Posts: 132 - iTrader: (
Don't use step down transformers, they wear out. The Pod XT runs on 9VAC 1300 milliamps, so just buy a line6 power supply from
www.sound1.no
BlueGrot
Find all posts by BlueGrot
03-01-2006, 06:15 PM
Ant1981
Posts: 2,181 - iTrader: (
Stepdown transformers wear out? Rubbish! LOL!!!
The power supply you mentioned, and ALL powersupplies are stepdown transformers!
lol!
Ant1981
Find all posts by Ant1981
03-02-2006, 05:28 PM
BlueGrot
"wearing out" was the wrong term, more like popping like flies. The cheap ones are poorly made devices which I've experience frying quite often, and other places in europe, the power companies aren't that thorough on whether the outlets supply 230V, 160V or 260V, so imagine touring with a band and using a power conditioner, and then have the thing pop in the middle of the set, with no replacements. Hooray.
And last but not least, why go complicated when you can to it simple.
BlueGrot
03-03-2006, 12:54 PM
Ant1981
Tip, If you don't want them to fry, get one that handles as much power that you can afford. That way it will run cooler.
Ant1981
03-03-2006, 01:29 PM
BlueGrot
But then they also draw much more wattage.
BlueGrot
03-04-2006, 06:11 AM
Ant1981
That's worth considering for running costs.
Ant1981
03-04-2006, 06:16 AM
Algiman
Posts: 2,553 - iTrader: (
The European transformer only runs at Euro voltage, so safe to assume that the US one will be 110v only.
Buy a new adapter - they're cheap enough.
Algiman
Find all posts by Algiman
03-04-2006, 06:22 AM
Algiman
http://www.bonnersmusic.co.uk/acatal...cessories.html
http://www.giggear.co.uk/home/index....op&prodid=1450
Algiman
03-23-2006, 05:52 AM
GonWild
Posts: 93 - iTrader: (
yeah.. you can buy a new adapter for your POD in Norway, OR buy a converter from 110v to 220v. I've tried both and it works excellent... why am I writing in english ? eheh...
GonWild
Find all posts by GonWild
which power supply for tube screamers
what program can i use other than power tabs?
where are the 5150 power tubes
power chords really necessary?
how often change power tubes
Pre and Power Amp Questions
DotNetTim
Gear and Equipment
02:52 AM
Tapping MIDI phantom power for multiple pedals
bduersch
Gear and Equipment
04:11 PM
converting US preamp to take Aus power?
Ki swordsman
Tech: Setup, Repairs and Mods
08:47 PM
AMP POWER - significance of watts
mmr7
08:49 AM
04:47 AM
