Originally Posted by markg5150
Kettles use lots of power when boiling, they might blow the fuse
Only if you are playing the guitar in the kitchen, they most likely won't share a fuse. But other than that you are correct, a water boiler, rice cooker or frying pan will use about 10 times more electricity than Marshall stack.
I'd put the kettle on the gas stove anyway and if you have an electric stove, you should really have triple phase 360V power, or enough to drive a small locomotive
