Old 08-16-2008, 11:04 PM
Wolfram  is offline
Posts: 911  -  iTrader: (0)
Reviews: 12
Pro Tools Help Needed
I have a Digidesign Pro Tools 003 Rack and an MBox 2 with PT 7.4
I have a HP laptop that does not have a FireWire input. The laptop is an Duo Core Intel Chip set with 2 Gig of RAM and runs Windows Vista on a 32 Bit system. I intend using the MBox 2 and the laptop as a portable recording system.
My main PC/DAW is a P4 (925X/XE Chipset) with a firewire input and 3 Gig of Ram running Windows XP attached to a Digi 003 Rack (well about to be anyway).
1. I am about to run PT 7.4 through the laptop and use the MBox 2 via USB 2.0. Any forseeable issues?
2. With my main PC/DAW I am currently running PT 7.1, should I completely uninstall this system prior to uploading PT 7.4?
3. What do I need to do to to my current PT music that I have created and how do I tranfer the old 7.1 files in to 7.4 for use ( I have been backing up everything)?
4. I am thinking of buying XP Pro (SP2) to create a new clean install on the PC, am I better off just buying vista or XP Pro (SP3) given that I can run Vista with 7.4?
If more detail on my IT systems is required just let me know.
I want to get all this sorted prior to booting up the 003 so I await your advice.
Cheers,
Wolfram
Old 08-17-2008, 01:16 PM
Rip  is offline
Posts: 396  -  iTrader: (0)
Re: Pro Tools Help Needed
http://duc.digidesign.com/
Old 08-19-2008, 09:06 AM
Wolfram  is offline
Reviews: 12
I went with Vista, clean install. No issues with the Mbox 2 and laptop. I have the factory bundle with the M Box 2 and I have transfered all of my plug in' across on to my clean system. All I need to do now is mount the 003 in a rack, tidy up and hit record.
-Wolfram
Old 09-11-2008, 11:14 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Just be aware that USB drives are not supported or recommended. Some have had success and others have had misery. Check the compatibility pages for a PCM-CIA firewire card so you can use an approved firewire external drive with your laptop(and also with your 003 setup).
pro tools
Guitar tools Jemwielder Tech: Setup, Repairs and Mods 6 02-02-2008 03:02 AM
pro tools Spooty777vai Recording Studio 7 02-11-2007 07:02 PM
tools of the trade...... btweensunandmoon Tech: Setup, Repairs and Mods 1 04-05-2003 03:09 PM
routing tools? yurich Tech: Setup, Repairs and Mods 5 07-30-2002 10:48 PM
Review: Simple Re-finishing - Tools needed and what to do ChrisReedSmith Tech: Setup, Repairs and Mods 0 04-14-2001 03:16 PM
