Recording Studio
Pro Tools Or Cubase?
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
03-05-2006, 02:44 PM
Darren Wonnacott
Posts: 52 - iTrader: (
Hey,
What are the main differences between
Pro Tools and Cubase?
Thanks
Darren
Darren Wonnacott
Visit Darren Wonnacott's homepage!
Find all posts by Darren Wonnacott
03-07-2006, 02:29 PM
Ibanut
Posts: 223 - iTrader: (
Re: Pro Tools Or Cubase?
Darren Wonnacott
Hey,
Thanks
Darren
The only real difference is that ProTools has to have a digidesign hardware to run. If you get a an LE system you can get an Mbox to run it but you only get to track 2 channels at a time. If you get a TDM system you will pay out the butt. A card for that system runs like 8 grand to start. It has 9 processers though to run all the plugins with no CPU being used. Its an expensive system. Most professional studios have a protools rig. Usually a control 24 .
Cubase is a semi pro version of Nuendo which is a professional recording software. Nuendo/Cubase can be ran with any computer/mixer. Its more versatile and unless you want to pay for digi hardware its the way to go. All the available plugins work for cubase too. The way the software operates is basically the same. Engineers like Chuck Ainley and Bob Bullock use nuendo so it cant be that bad.
Ibanut
Find all posts by Ibanut
03-07-2006, 06:09 PM
Rotti
Posts: 3,341 - iTrader: (
How about the newest version on Cakewalk's Sonar? I recently tried and liked it. Just wondering what others think of it.
Rotti
Visit Rotti's homepage!
Find all posts by Rotti
03-07-2006, 07:32 PM
JESTER700
Posts: 2,234 - iTrader: (
There are all kinds of good software, each with adherents and detractors. I like Vegas, but I also do video and don't need MIDI. Many like Sonar, Nuendo, Audition, Cubase, Traktion, Samplitude... Many have trial versions, so it might be worth some downloading time to take a peek.
JESTER700
Find all posts by JESTER700
03-07-2006, 08:43 PM
David McCarroll
Posts: 2,049 - iTrader: (
[quote=Ibanut]The only real difference is that ProTools has to have a digidesign hardware to run. If you get a an LE system you can get an Mbox to run it but you only get to track 2 channels at a time. If you get a TDM system you will pay out the butt. A card for that system runs like 8 grand to start. It has 9 processers though to run all the plugins with no CPU being used. Its an expensive system. Most professional studios have a protools rig. Usually a control 24 . QUOTE]
There is an in-between solution in the form of the Digi 002 - runs Pro-Tools LE, which is very powerful recording software indeed. The thing Pro-Tools has over Cubase or Logic (IMHO) is that Pro-Tools has an installed base of about 95% of all pro recording studios - when you save out a Pro-Tools session onto an external drive or a CD (or whatever) - you can trot down to your local studio, plug it into their Pro-tools TDM system and it will come up exactly as it does on your Mac or PC.
This means that you can, say, record all your vocals and drums using the mics and acoustics of a great studio, go home, overdub all your guitars, keys, bass etc, edit and rough mix, then take the whole thing back into a studio and do final mixes and mastering in the environment of a proper studio using their monitors/outboard effects/mastering suite etc - it really works, it's how we record albums and it saves a small fortune in studio time.
You can probably do the same thing in Cubase or Logic, I don't know, it's just that PTs IS the industry standard, and certainly the recording quality we've got out of our Pro-Tools LE setup has been very pleasantly surprising.
The Digi 002 is not expensive, and comes with a bunch of really good plug ins - whether you choose PT, Cubase or Logic (or whatever), you still have to buy a Digital interface, so there is a hardware cost no matter what program you choose; you'll also need a second FAST hard drive, and as much RAM as you can afford to stick in your computer.
By jingos it's fun though!!
Cheers
David
David McCarroll
Find all posts by David McCarroll
03-07-2006, 11:05 PM
JESTER700
That's true about PT being the standard and in many studos. But PT can save as WAV files if you want, and you can set up a quick mix at home with any of the mentioned PC softwares if overdubbing at home is the main concern. The problem is, you can't then work on a mix with pans, fades, and FX and have those port to a studio's rig. It'd be nice if there was a standard for this, since the instructions aren't any more complicated than MIDI. all those "other guys" should have thought of this years ago; then maybe they wouldn't be so "locked out".
JESTER700
03-08-2006, 11:43 AM
Ant1981
Posts: 2,181 - iTrader: (
So for home stuff its cu base? what sort of interface would we use to get xlr's in and all that stuff?
Ant1981
Find all posts by Ant1981
03-08-2006, 06:13 PM
JESTER700
Well, of the TWO I'd say yeah. Any reason why you're already set on those two when you weren't sure of the differences between them?
Actually, I'd ask what your specific needs were...
BTW, there are TONS of front ends, in many configurations. Again, what are your needs?
JESTER700
03-08-2006, 06:30 PM
David McCarroll
Ant1981
Makes no difference - it's up to your preference - I've used ProTools LE for six years now, and was using Cubase 5 before that - we swapped to ProTools for the reasons I outlined above - having said that, ProTools is a very easy audio editor, and a not so easy MIDI editor - I'd describe Cubase as the opposite of that. If you are interested in looking at ProTools - have a look at:
www.digidesign.com
- go to LE systems and check out the 002
rack system
. BTW, I'm pretty sure you can run Cubase via this box anyway.
Cheers
David
David McCarroll
03-08-2006, 06:33 PM
Ant1981
I thought pro tools was a well expensive route to take? Really don't want to spend a hell load on recording. I was thinking of a multitrack and the pc stuff as another option.
Ant1981
03-13-2006, 03:16 AM
Ant1981
Sorry for being naive or something, but what exactly is the difference between Audio and Midi on these recording software systems?
Ant1981
03-13-2006, 05:18 AM
JoeJoe
Posts: 587 - iTrader: (
I'm also interested in this...
I just looked at the digidesign site and i really don't want to spend much money on a home recording thing (the 002 rack is just a little more than i want to spend) i then looked at the M-2 which is less than 500 usd...
is this any good?
JoeJoe
Find all posts by JoeJoe
03-13-2006, 06:15 AM
Ant1981
I've been looking at the Alesis firewire mixers. They come with Cubase LE and with a firewire mixer, you get to track as many channels as you like, as many channels as the mixer has, 8, 12 or 16 with the Alesis FireWire and Cubase.
Ant1981
03-13-2006, 08:25 AM
JoeJoe
thanks for the info! i'll look into that
JoeJoe
03-13-2006, 10:48 AM
timi_h
Posts: 1,104 - iTrader: (
try logic, its a great bit of software
timi_h
Find all posts by timi_h
rack system
what does s&k tools stand for
how to use pro tools LE 8 with digi 001 dae
how to get EZ drummer to work in pro tools
how does sonar compare t cubase
how to level a high fret with standard tools
buying reconditioned tools, worth it?
SilverSurfer2
Off-topic / Miscellaneous
03:18 PM
Intonation Tools
guam-jem
Tech: Setup, Repairs and Mods
07:03 PM
Audio out of sync in Cubase VST
Azrael
04:04 PM
Cubase problems please help!
FinnJ
Recording Studio
04:08 PM
BR8 to Cubase - Having trouble recording BR8 to Cubase
MikeyJ
Gear and Equipment
08:01 PM
03:53 AM
