Recording Studio
REALTEK HD line and spdif out ??? need some advice
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
09-14-2007, 11:31 AM
IbanezFreak777
Posts: 3,486 - iTrader: (
Reviews: 24
Ok I recently built myself a new computer. Its awesome and is off the hook etc...
I recently bought some Behringer studio monitor speakers, which have Digital line input. and my realtek HD audio card has a spdif output.
It all works great. Music plays through these speakers so well, the sound is awesome. I plug my Axe into the line in and can see that sound from my guitar is being recorded onto Acid pro. I can even hear the guitar during playback after I have stopped recording, but I cannot seem to hear the guitar during recording process.
What is going on. My old PC had no problems. Plug guitar into line in and pretty much use my computer as a mini Amp. This is a very important part of the recording process. Being able to hear the guitar during the actual recording.
any ideas would be great, thanks in advance if any one can shed some light
IbanezFreak777
Visit IbanezFreak777's homepage!
Find all posts by IbanezFreak777
09-14-2007, 12:13 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: REALTEK HD line and spdif out ??? need some advice
That's really weird that you can't monitor the recording process. I am able to do that with my GT-Pro when it's plugged into my JSX. Check the settings on Acid because it could be preventing monitoring while recording.
Jimmy
jb4674
Find all posts by jb4674
09-14-2007, 12:32 PM
Wild_Child
Posts: 681 - iTrader: (
Reviews: 3
jb4674
Jimmy
Thats what I was thinking.. but then there's no reason there should be an option to do that because why wouldn't you want to monitor while you are recording? There are options in cubase to turn off monitoring while record isn't enabled, but not the other way around.
Does your sound card have a software mixer? If so, there's a possibility your spdif in isn't linked to the spdif out or vice versa. I'd imagine that would cause the opposite problem to what you have, but it's a possibility so I thought I'd suggest it.
Congrats on the build BTW, I built a PC a few months ago.. the most frustrating and confusing task I've ever undertaken, but very rewarding in the end.
Wild_Child
Visit Wild_Child's homepage!
Find all posts by Wild_Child
09-14-2007, 01:40 PM
yoyo1299
Posts: 637 - iTrader: (
Wild_Child
[b]Thats what I was thinking.. but then there's no reason there should be an option to do that because why wouldn't you want to monitor while you are recording? There are options in cubase to turn off monitoring while record isn't enabled, but not the other way around.[b/]
the option of being able to turn monitoring on and off is actually very useful. if you're micing a cab, there's no reason you'd want to monitor what you're playing cuz you can hear it live, and all that will happen is you'll get the sound coming out of your monitors also recorded, so a double record would happen, causing problems.
yoyo1299
Find all posts by yoyo1299
09-14-2007, 01:46 PM
Wild_Child
Reviews: 3
yoyo1299
I suppose I've become too used to direct recording...
Then again, when you're recording a from a mic'd cab, you'd still want to hear the sound you're recording rather than the sound in the room. You would also need to hear the rest of the track you're supposed to be recording onto! Usually in that kind of situation, you'd have the cab in an isolated room, or otherwise use headphones for monitoring.
Wild_Child
09-14-2007, 09:53 PM
IbanezFreak777
Reviews: 24
Ok problem solved. Atleast for now.. For some reason line in signal is not getting sent through to the spdif output. But a standard mini jack cable from the analogue speaker output to the line in on my behringer gives me the guitars sound. Luckily these behringer speaker allow of digital input and an analogue input at the same time. These speakers are so good I can't rave about them enough. Check em out on
http://www.behringer.com/MS20/index.cfm?lang=eng
They were cheap and they are the best speakers I have ever bought as far as recording music goes. 2 seperate volumes for digital and analogue which can be use at the same time, 24 bit 192 khz and digital tosslink inputs and amplified aswell all for $150 AUS thats amazing !!
Thanks for your help guys
IbanezFreak777
09-14-2007, 10:42 PM
yoyo1299
those speakers look REALLY nice. but MF does NOT sell them... hmmmm. they're only like $100 bucks US as well! where can i get ahold of these babies?
yoyo1299
09-15-2007, 12:48 AM
jb4674
Reviews: 6
I think z zounds has them yoyo. They also have the MS40 as well
MS20:
http://www.*******.com/item--BEHMS20
MS40:
http://www.*******.com/item--BEHMS40
Jimmy
jb4674
09-15-2007, 10:15 AM
yoyo1299
yeah, i eventually found them. they look good don't they? but they seem to be really small, only like 11"
yoyo1299
09-15-2007, 02:03 PM
IbanezFreak777
Reviews: 24
Yeah they are small, they are near field speakers. If your going to make music on the PC, and master it yourself. these will give you a true reproduction of what the music will sound like. They don't need to be big because they are near field. They have a real big sound for their size.
My 2 cents they are worth the money even as great PC speakers. Music and cd's sound so clear from them its great...
IbanezFreak777
09-15-2007, 02:29 PM
yoyo1299
i'm getting a pair ASAP!
yoyo1299
how to unmute line in?
how to line in guitar to pc
crate blue voodoo + how to use line out
whats is ibanez 2010 line up?
how to install six-in-line staggered locking tuners+stratocaster
USB / SPDIF recording via POD XT or XT PRO
Ralph khoury
Recording Studio
10:35 AM
10:05 AM
