Old 05-15-2006, 04:48 PM
Epicus Furor  is offline
Posts: 519  -  iTrader: (0)
Recording 2 + intruments on Hard Drive
I've pretty much got my recording set-up up and running, Imac G5 - Cubase SX3 - Line 6 Toneport (tweaked some pretty good sounds) so now i'm wondering how i can if possible record 2 or more instruments simutanuosly on Cubase (Toneport has 1 instrument input and 1 mic input), will i need a mixer with more inputs .. if so what can you reccomend on a tightish buget that will do the job? Cheers
Old 05-15-2006, 07:09 PM
Ibanut  is offline
Posts: 223  -  iTrader: (2)
Re: Recording 2 + intruments on Hard Drive
Try looking at some firewire interfaces. You can get 8 inputs. You can mix "in the box" You can also get a cheap 12 channell mixer.
Old 05-15-2006, 10:31 PM
Ant1981  is offline
Posts: 2,181  -  iTrader: (3)
The mixer in cubase is all you need, so yea, look for a firewire interface with mic pres.
Old 05-16-2006, 10:40 AM
sorry could you explain what a firewire interface is and what it does? If i got a cheap channel mixer, would i be able to use it in co-existence with the cubase mixer so it controls it?
Old 05-16-2006, 11:34 AM
Ant1981  is offline
The firewire interface is this - Interface, which is a device that has the inputs for mics ect so that you can connect to your pc - through firewire, which is a type of connection, as is USB a type of connection.
You can use a mixer, again, would need a firewire interface built into it(dont bother with USB). But another mixer is just going to confuse you. The cubase mixer is all you need.
Old 05-16-2006, 08:29 PM
megadeth  is offline
Posts: 1,221  -  iTrader: (10)
I am just wondering why would you want to record 2 or more tracks at one time?
Old 05-16-2006, 08:50 PM
Ant1981  is offline
Why wouldn't he? Many people record many tracks at a time.
It's called multitracking.
List your recording gear and your thoughts on your gear.. gemini8026 Recording Studio 39 03-14-2007 07:37 PM
A way to save video google vid's on your hard drive! JoeJoe Off-topic / Miscellaneous 9 01-18-2006 06:26 PM
Getting a new recording PC... what hardware to get? bduersch Recording Studio 21 05-29-2003 04:51 PM
