Recording Studio
Recording a guitar amp
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
10-27-2009, 12:12 PM
mindwalker
Posts: 184 - iTrader: (
Hey,
This has been asked plenty of times but the information is so vast that I found I could ask a little bit about this!
Maybe it's better to first put my restrictions
I live in a flat so I cannot afford to make a lot of noise. Also I might need to rehearse with friends and a drummer so I need some portability and power. On top of this I would like to record to my pc as well. So far the only piece of gear that I have besides my guitar is a Pod X3 live.
I'm looking into buying a guitar amp with tubes for the sake of having real tubes sound and to jam with friends (50watts amp or more)! Out of the guitar tube amps available, there are some that provide a line out speaker emulated out, and some that don't. So what would the options be then:
- Guitar amp with line out and speaker emulation, just connect straight to
recording
interface. Does this sound good at all ?
- Guitar amp with a mic, connected to a mixer or recording interface. Seems to be the best approach but requires the amplifier to be turned out loud which can be a problem for me (and maybe a dedicated recording room)
- Connect amps fx out into the POD, and record from the POD bypassing pre-amp and using a speaker and mic simulation. Will this work good enough ? I would still need to crank my amp I believe, as you can't just mute it
I've seen a lot of videos on youtube that sound like crap so I'm assuming those are recorded with a laptop's internal mic..
Thanks for any hints guys!
mindwalker
Find all posts by mindwalker
10-27-2009, 04:48 PM
nato101010
Posts: 1,002 - iTrader: (
Re: Recording a guitar amp
mindwalker
- Guitar amp with line out and speaker emulation, just connect straight to recording interface. Does this sound good at all ?
Well, since you said you can't make a lot of noise, and i know no one that plays with a band with even 1/3 of 50 watts when jamming! And its tube power at that! Try like 15- maybe 20 watts.
And, guitar amp with mic is best sounding idea.
nato101010
Visit nato101010's homepage!
Find all posts by nato101010
10-27-2009, 06:07 PM
Hub
Posts: 282 - iTrader: (
+1
And if you have like a closet or something in your apartment you can soundproof that and put the amp in there. Add an sm57 and a preamp and your done.
Hub
Find all posts by Hub
10-28-2009, 02:17 AM
Cam-Vai
Posts: 313 - iTrader: (
Reviews: 4
id get a krank krankenstein j or rev jr or even a rev pro jr
these have awesome blues channels and can play almost any type of metal
or by a carvin legacy 2 combo of **** (carvin scratch and dent)
they have watt switching from 100-5o-25
plus isnt the preamp in the amp? or do you mean to plug the mic into? i know nothing of recording pretty much:S
have fun!
cam-vai
Cam-Vai
Find all posts by Cam-Vai
10-28-2009, 07:41 AM
mindwalker
Hub
+1
How does this affect the sound of the amp as opposed to mic'ing it in an open room ? I would imagine it to sound much fatter.. muffled ? Dunno.. I have no real hands on experience
mindwalker
10-28-2009, 09:44 AM
GuitarGuru
Posts: 763 - iTrader: (
Reviews: 3
You can record direct and use amp simulation software. It's not that bad, you would be surprised. Amp Farm. Get Pro Tools with it.
http://www.digidesign.com/index.cfm?itemid=1001
GuitarGuru
Visit GuitarGuru's homepage!
Find all posts by GuitarGuru
10-28-2009, 12:46 PM
Hub
mindwalker
It really doesn't change the recorded sound all that much since the amp is close miced right on the speaker, but it does remove those loud nasty low frequency thumps caused by your neighbors trying to break through your floor/walls/roof when playing cranked
Hub
11-02-2009, 09:46 PM
j.t..i.
Posts: 129 - iTrader: (
recording with a mic'd cab doesn't require high volumes at all. i record at very low volumes.
j.t..i.
Find all posts by j.t..i.
11-03-2009, 06:52 AM
mindwalker
j.t..i.
But that must require an amp that sounds good at low volumes right ? Cannot be one of those that only screams the juice out when cranked..
mindwalker
11-04-2009, 04:35 AM
humpy
Posts: 207 - iTrader: (
what about an Orange tiny terror combo? Only 7 watts
humpy
Find all posts by humpy
11-12-2009, 06:59 AM
mindwalker
How can you get and record nice guitar stereo effects (like panning from left to right) or bouncing stereo delays by mic'ing the amp ? If you put your effects pedals before the amp and the mic in the end, then all you'll get is a mono signal into the mixer / PA / recording device. Would you have to post-process this on the computer ? Like adding the delay only in the recording software ?
How are people doing this ? I'm kind on a newbie in this kinda stuff
mindwalker
11-12-2009, 07:44 PM
LonePhantom
Posts: 5,365 - iTrader: (
Reviews: 98
Blackstar HT-5, has a speaker emulator for PC recording, and going out to a PA, etc. Plus being 5 watts it sounds good at lower levels. Pair it with the right speaker combo and you'll be right for jams as well.
That's why I got one.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
11-14-2009, 09:17 AM
Hub
mindwalker
Well, you could run your rig in stereo, but that will require two mics when recording also...
Hub
11-14-2009, 10:55 AM
jemaholic
Posts: 2,806 - iTrader: (
Hub
That would technically still be a mono mix as the source is mono. Best way is to record one track panned left and record another of the same thing panned right. A slight change in amp settings would make the seperation much more noticeable too.
As far as a tube amp that sounds good at low volume - make sure it has a master volume control so you can saturate the channel gain and then keep the overall volume down with the master.
You didn't indicate what type of music you play -so I'll assume it's rock: I've had scores of different amps- Fender, Vox, Budda, Dr.Z, Hi-Watt, Peavey, Orange, Line6, H&K, etc.... and for me the best sounding is Marshall. I would suggest you go to a large music store and invest some time playing lots of different amps until you find one that works for you.
jemaholic
Visit jemaholic's homepage!
Find all posts by jemaholic
11-14-2009, 01:17 PM
Hub
jemaholic
Yes, you're right, I was merely thinking about the actual delay effect and whatnot
Hub
recording
recording audio with mic
how do i fix a synsonics guitar?
is it ok to ding your guitar
what age guitar
how to swirl a guitar
which instrument to record first in a recording studio
Acoustic guitar recording
Ant1981
Recording Studio
11:03 AM
Recording Guitar
MojoMike
Recording Studio
10:13 AM
Recording guitar direct
SuperJemBoy
Recording Studio
03:35 AM
Vocal/guitar recording...
Martel
Recording Studio
02:39 PM
Which soundcard for guitar recording?
bbovee
Gear and Equipment
08:11 PM
06:36 PM
