Recording Studio
Recording directly into a sound card
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
03-11-2005, 09:33 PM
Xavier 7
Posts: 176 - iTrader: (
I have a Nomad 45 amp with a recording output, and was wondering what kind of equipment you use to record directly into your computer/sound card. Would I be able to use something like this?
http://www.newegg.com/app/viewproduc...121-106&DEPA=0
or this?
http://www.newegg.com/app/ViewProduc...121-115&depa=0
Thanks
Xavier 7
Find all posts by Xavier 7
03-11-2005, 11:16 PM
Rotti
Posts: 3,341 - iTrader: (
Re: Recording directly into a sound card
Yes either of those cards would do a great job.
Rotti
Visit Rotti's homepage!
Find all posts by Rotti
03-11-2005, 11:19 PM
Xavier 7
Okay, but the first one doesn't look like it has an input that would accommodate a guitar cable. Would the second card be a wiser choice?
Xavier 7
03-11-2005, 11:24 PM
JESTER700
Posts: 2,234 - iTrader: (
The first one has that breakout package, so it may. In any case, an adapter to do the job would only be a few bucks. I'm with Rotti; either should work well.
JESTER700
Find all posts by JESTER700
03-12-2005, 02:10 AM
Xavier 7
What sort of adaptor? One that converts the large jack into a small,typically headphone, sized one?
Xavier 7
03-12-2005, 08:41 AM
Rotti
I'm prety sure that card has rca type inputs and outputs. Either way it's not a problem. There are adapters for every possible situation.
Rotti
03-12-2005, 10:23 AM
bduersch
Posts: 1,357 - iTrader: (
The 1010 has (balanced) 1/4" jacks, while the 1010LT has (unbalanced) RCA jacks.
I use two 1010LT's in my system, so I had to go to radio shack and clean them out of $3 1/4" -> RCA adapters. Problem solved.
--B
bduersch
Visit bduersch's homepage!
Find all posts by bduersch
03-13-2005, 03:54 AM
Xavier 7
Went to the store today and I bought this:
http://www.newegg.com/app/ViewProduc...102-164&depa=0
They didn't have the two I mentioned above but this card seems like it will do the job.
Thanks for the info everyone.
Xavier 7
03-13-2005, 09:09 AM
Rotti
Thats more of a gaming card than a recording card. A lot of people will tell you it's not good for recording, but it will work. As long as it has asio drivers you will get good performance from all the recording apps.
Rotti
03-19-2005, 10:11 PM
maggotcontrol
Posts: 28 - iTrader: (
I've have the Delta 44 for a few years and it still rocks. It doesn't have mic-preamps but the I/O's are line level so it should take the Nomad's output without any conversion. Don't waste your money on a gamer's card as they aren't designed for recording. Lots of reasons for that but let's just say don't bother with them.
maggotcontrol
Visit maggotcontrol's homepage!
Find all posts by maggotcontrol
03-19-2005, 10:33 PM
Drew
Posts: 4,538 - iTrader: (
A Nomad-45's recording out (oh, I'm a near-religious devotee of that amp, by the way), while useable, isn't THAT good. Especially since it'll give you very useable tones at low volumes, it's definitely worth your while to grab a mic and mic the thing up.
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
03-20-2005, 02:59 AM
Xavier 7
Seems like I can't turn the volume up too high when the amp is plugged straight into the card. It's too much and causes horrible static. Anyway to fix this? I'm a newbie when it comes to recording.
What's this about mic preamps?
Thanks
Xavier 7
03-20-2005, 03:05 AM
maggotcontrol
The 'line input' is where you want to be connected and not the 'mic input.' If that's already set, then you can't do much about it other than reduce the volume of the amp. You also bought the wrong card for recording although you could get away with it.
maggotcontrol
03-20-2005, 04:19 AM
Xavier 7
I realize I didn't buy the right card (I hate being compulsive) but whenever I plug it in the line in jack it only records in mono while the mic in records in stereo. How do I record in stereo using the line in jack?
Xavier 7
03-20-2005, 10:29 AM
pr0cyon
Posts: 63 - iTrader: (
Your amp isn't stereo, so you can't record it in stereo. Just fix it with the recording software you're using
pr0cyon
Visit pr0cyon's homepage!
Find all posts by pr0cyon
would active pickup sound bad without batteries ?
how to achieve brown sound
how does basswood sound
how to sound like korn
which instrument to record first in a recording studio
Sound Forge - basic recording dialemma
tomizm
Recording Studio
07:27 AM
Need help achieveing an ahkward sound.
IWantAJem
Gear and Equipment
04:03 PM
06:15 AM
