Recording Studio
Recording in 5.1, 6.1, 7.1 etc surround sound
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
07-28-2006, 03:58 PM
adamcbest
Posts: 870 - iTrader: (
anyone ever try this or hear of anyone trying it. I think it would be cool to be able to record something like that and put certain parts in the left surround or right front or do crazy effects like rotate around all the speakers. Obviously you couldn't reproduce it live, but it would be cool if somehow you could record experimental albums using surround sound that you could play through a surround sound stereo system. Any ideas how you may pull this off??
04:38 PM
adamcbest
Find all posts by adamcbest
07-28-2006, 04:57 PM
Demiurge
Posts: 883 - iTrader: (
Re: Recording in 5.1, 6.1, 7.1 etc surround sound
A couple years back in college I did a 5.1 surround sound project. I basically took a really thick synth composition I had and spread out the over the channels (we had a new performance hall where the main speaker system supported up to 8 separate surround-sound channels, so it sounded huge). I used Pro-Tools for it and I was really disappointed with it because there was no good way to automate channel shifts- like if I wanted to have the track playing in the left-front channel slowly shift to left-back (as if to spin around you), it was a real PITA. I'm sure Pro-Tools has been updated to handle that process better, though.
Demiurge
Find all posts by Demiurge
07-31-2006, 01:03 AM
Ozzdoc
Posts: 1,008 - iTrader: (
I do.
I have a 7.1 Logitech system running through a Creative Soundblaster X-fi Platnuim.
It's not as great as monitors etc.. since if a computer only has a 2 speaker setup, your going to get complete differnt sounds then out of a 7.1.
Ozzdoc
Find all posts by Ozzdoc
07-31-2006, 12:11 PM
Ibanut
Posts: 223 - iTrader: (
You can track in surround but you need a mic thats crazy expensive and looks like a head. The mics are in the ears. Mixing in surround is easy if you have the gear for it. Pro Tools HD has surround capabilities. LE doesnt. Its easy to have get the sounds to move around too. The automation in PT is great. I know that the insane clown posse did a surround mix on one of there cds. You cant playback a surround mix on all players though. You'll need a player that reads the surround code. If you have the right gear and software you can do a surround mix pretty easily.
Ibanut
Find all posts by Ibanut
07-31-2006, 03:48 PM
Demiurge
Insult upon injury.... I read that damn manual a bunch of times to try to figure out how to automate, but the Insane Clown Posse apparently figured it out. :-(
Demiurge
07-31-2006, 06:52 PM
Ibanut
Demiurge
I dont know about the version you used but the version I use is easy. Just play back and put the automation mode in latch and as its playing back then do your pans then go back to read mode. You can also draw automation in the pan part of the edit window
Ibanut
07-31-2006, 06:55 PM
elcid
Posts: 8,721 - iTrader: (
I don't really see the point of it, how many people have the time or patience to sit in the middle of one room and just listen to an entire album. I guess in some sort of self serving musician way it could be cool, but not for the average listener. Usually when I have music on I'm doing work around the house or something.
elcid
Find all posts by elcid
08-01-2006, 01:06 PM
Ibanut
elcid
Surround mixes are about to take off. Alot of car makers are making there car stereos play in surround. Lots of pro studios now have the capability of doing a surround mix. Its the future yea baby!!!!!!!!!!!!
Ibanut
would active pickup sound bad without batteries ?
how to achieve brown sound
how does basswood sound
how to sound like korn
which instrument to record first in a recording studio
Transcript of Aussie Vai I'view (didnt know where to put it)
TheOrangeChannel
12:52 AM
need a studio-quality PC sound card
Max-T
Gear and Equipment
05:59 AM
Guys, Wheres MY sound!?
DrPuls
Gear and Equipment
10:27 AM
sound cards
Al M
Recording Studio
04:52 PM
DiMarzio Humbuckers - For a Modern sound in the Bridge
Skully
Gear and Equipment
10:48 AM
03:38 PM
