Originally Posted by Kerem
as a conclusion, you have to use headphones
If your amp is in the same room as your monitors.
In reality, most microphones are fairly directional, and if you are playing at a reasonable volume, you'll actually get very little spill from your monitoring through the mic in front of your amp - you can noise gate some of that out, or even manually erase the parts of the track where your guitar isn't playing - worth experimenting with.
The other thing is, if you are happy with the sounds you get out of a Pod, you'll probably have a fair amount of trouble bettering them with a recorded amp - Pod sounds are tweaked to give you the emulated sound of a good amp in a good room recorded with a good mic - that's why they sound so good!
