Old 01-09-2010, 12:12 PM
MattyG  is offline
Posts: 360  -  iTrader: (4)
Reducing pick attack noise in recording
When I record I get a lot of pick noise as I strike each note. It's starting to bug me as I become more aware of it!
It may be a matter of playing technique that needs to be addressed but I was wondering if someone has any tips for reducing the noise.
I record direct from a pod xtpro into a multitracker. Not the most elaborate setup but it does the job for now.
The noise I'm talking about is most noticeable on the plain unwound strings especially when playing slow single notes with distortion.
Thanks
Old 01-09-2010, 12:51 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
Re: Reducing pick attack noise in recording
A good post-EQ will help alleviate alot of the scratch.
I haven't had that problem, but I bet using pointy picks, like Dunlop Jazz or Planet Waves Black Ice picks. I figure if there is less contact versus a round pick, there would be less noise.
I don't know if this would work, but perhaps lowering the pickups?
Or maybe coated strings? Elixirs?
Old 01-09-2010, 12:52 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Here are some things to consider:
- Use a pick made of a different material than the one you're currently using. I used to use Dunlop Big Stubbies until I started changing my rig and core sound. At some point the "clicky" sound of the pick became annoying so I switched to more standard Ibanez sandpaper picks which are made from plain ol' delrin or some kind of plastic I don't remember the name of.
- Some pickups reproduce pick attack more than others but I would look at this as a last resort.
- Change the EQ on amp and/or pedals.
- Change the angle of attack of your pick. The close the picks comes to striking the string at a 90 degree angle, the more the sound of the pick attack comes through. However, this can also affect speed and of course tone but it's an easy thing to try.
Old 01-09-2010, 12:58 PM
skins345669  is offline
Posts: 835  -  iTrader: (0)
Which materials reduce the sound of your pick attack?
I'm currently using normal Black Jazz III XLs and know that they produce that shape in other materials. Would using those be effective?
Old 01-09-2010, 01:47 PM
toneboy  is offline
The harder the material is, the more "pick click" it is capable of but you have to consider all the factors (angle of pick attack, where you pick on the string's length (closer to the bridge is brighter), pickups, and EQ).
Playing around with picking angle, where you pick on the string and EQ are the things to try first because they are the cheapest solutions.
Old 01-09-2010, 02:30 PM
S-man  is offline
Posts: 1,757  -  iTrader: (0)
Now that you have noticed it...you may be focusing on it... making it sound worse than it really is. Just a thought.
But yeah... all of the other advice sounds good as well.
Old 01-09-2010, 03:01 PM
I've spent ages getting my pick attack to where it is so it's as energy efficient (if that's not the most out of context use of that phrase I've ever heard, I don't know what is) and effective as possible, so I'd rather not have to start fiddling with it again. Which are the softer materials used for picks? Ultex?
Old 01-09-2010, 03:21 PM
toneboy  is offline
Ultex, tortex, delrin and polyacetal.
Old 01-09-2010, 03:30 PM
MattyG  is offline
Thanks for the responses
Old 01-09-2010, 03:35 PM
MattyG  is offline
I'm wondering now if it's because my picks are a little old. The edges probably have hundreds of little notches from wear and tear. Perhaps a nice new pick will help.
Old 01-09-2010, 04:39 PM
toneboy  is offline
After I've used a pic for a little while, the edges become beveled and the point gets widdled down. I just throw those in the pick recycle jar so eventually I'll try and file new points on them. With the Ibanez pics, I know it's time for a new pick when the logo is just about worn off.
That said, picks like strings are disposable resource. I usually buy about a gross at a time. At this point I have about 500-600 pics and every 3-4 months, I buy a gross.
Old 01-09-2010, 04:51 PM
MattyG  is offline
Yea I've tried reshaping picks but it never works well for me! I use jazz iii and they're pretty expensive but maybe it's time to stock up again
Old 01-09-2010, 05:23 PM
toneboy  is offline
Heh, you might pay $3/6 whereas I pay $5 for 6 Ibanez Sandpaper picks but man I love 'em! The sandpaper really prevent slippage.
Old 01-09-2010, 05:53 PM
trouble311  is offline
Posts: 643  -  iTrader: (3)
Try the Ultex Sharps...the shape (almost exact...you can lay the Jazz III over the Ultex Sharp, and it is nearly identical) and feel are pretty much the same, with much less noise and better tone. I use the 1.40 MM, and they are almost exactly as thick as the Jazz III XLs.
Old 01-09-2010, 06:07 PM
Awesome. Thanks.
Sorry to steal your thread dude, but, which which is closer in size to the XLs, an Ultex sharp or the Ultex Jazz III?
Reducing background sounds while using SM57? Myst and rain Gear and Equipment 6 06-25-2009 04:07 PM
pick ups excess noise madmecca Other Ibanez Guitars (including Premiums) 0 05-22-2009 03:39 PM
pick attack sound EL-CeeDee Gear and Equipment 4 02-13-2006 07:23 PM
heavy pick attack = speed/accuracy vette6600 Guitar Lessons & Music Theory 32 11-07-2005 10:23 PM
Pick noise keithb Gear and Equipment 5 10-18-2003 06:38 AM
