Old 09-26-2007, 12:55 AM
SilverSurfer2  is offline
Posts: 550  -  iTrader: (2)
setting up FCB1010 expression to send CC#4
I'm trying to setup my FCB1010 to control the wah in Gearbox plugin, and also the volume.
After attempts to program the FCB to transmit CC#4, and CC#7 the only result i got was that Expression pedal B controls the Treble EQ know on the amp.....not the wah.
I setup all my MIDI connections and interface correctly in Gearbox, and FCB. Basically, FCB out, to MIDI in on my MIDI interface.
I dont know if my FCB is not working right because according to the manual, i'm supposed to see the Value 1 LED (green LED) light up after i press ENTER to confirm the CC # i entered, and i am not seeing this LED light up after doing exactly what the manual says.
I know that some of you are using this MIDI controller, so i hope to get some help or advice.
I tried recalibrating everything, and all the LEDS lit up during the tests etc.....
I have a feeling my FCB is not working right, because i'm not seeing the VALUE 1/VALUE2 LEDS lighting up when the manual says they should light up, after going through the steps in the manual.........
All i need to do is set it up to transmit CC#4 and CC#7 and i'm all set........but so far it's not working.
expression pedal, midi controller
Simple MIDI expression pedal for Gearbox wah/volume, pitch etc... SilverSurfer2 Gear and Equipment 2 08-07-2007 01:33 PM
Midi Expression Pedal Zeppel Gear and Equipment 6 01-19-2006 11:40 PM
Whammy, Pod, FCB1010, Cube 30 amp (UK) hexa-db Classified Ads: Guitars and Gear 4 03-31-2005 03:45 PM
G-Major and Behringer FCB1010 - HELP! JiMoSiTY Gear and Equipment 5 08-08-2003 06:58 AM
Any problem setting up for BEADGB? - Any problem setting up Pudreaux JEM and Universe Guitars 2 06-28-2001 03:56 PM
