Okay here's the deal. I've been kinda looking around at some recording options for a bit now and have kinda come up with some ideas. I would like to keep this fairly simple and achieve good results. I don't need to end up ultra-professional but I would like the best bang for the buck here. I plan on intergrating into my current pc that i built within the last year. My system is a athlon 3200 64bit, 1 gig of DDR ram running in dual mode, 2 120GB 7200RPM WD HD's and a soundblaster 5.1 live card for basics. I built it to mainly handle different multimedia formats, i record a lot of tv and dvd files, and do grahic design work on it.
Now to get to what I want to do. So far I have decided that I want to use the Behringer V-AMP Pro(the rack mountable one) as my main modeler and such instead of a PODxt. I have a few other stomp-boxes and overdrives I might run in front of the V-AMP as well. I also have a Peavey 112 studio pro(65 watts) that i have liked for the past few years as well. It does have a speaker output (8 ohm min.) that I would imagine would be the best place to take my signal from to put to the V-AMP. Depending on the overall sound of thigns I might or might not use the Peavey at all. Now from the V-AMP I would probably like to go right into the Soundblaster card if possible. It does have a
Midi controller if that makes a difference. I already have some software that I'll use, cubase,cakewalk,acid works so that shouldb't be a issue. That is about all I really have at the moment.
So basicly what I need help on is what else do I need, will I need a DI box as well, or would it not be needed? Mini mixer or something needed or can i just mix and eq with my software. Will the soundblaster card present any problems, is there perhaps a different card I can also use that might work better for around $100. Also since the V-amp pro is more of a rackable unit do i need anything else to work with it, or can i just use it standalone in my room? I know the order to connect everything is somewhat subjective but what are some recomendations for the equipment I have listed. I'm also open to here about other thigns, but I want to keep the price down to below $500 if possible. which includes $160 for the new V-AMP. Thanks in advance to any comments.
