Re: Taking the ground plug out of a 3 prong cable. Problem?
Ground isolation is the key. If removing the ground gets rid of the noise you probably have a ground loop. Not too many ways to eliminate ground loop problems with out changing your configuration or installing some type of ground isolation.
It's never a good idea to remove the grounding conductor from a circuit. It is there for your physical protection. You could potentially energize the metal chassis on your components. More likely if you plug into a power source with reverse polarity.... More common than you'd think.
Reason: spelling
